| » It's VOMITING water!! |
Model Number: GLGH1642FSO Brand: Frigidaire Age: 5 - 10 years
Has anyone ever heard of this problem??
I have a front load stacked washer and dryer (Frigidaire Gallery series Laundry Center) that has worked pretty flawlessly for 3+ years. Lately I'm seeing water on the deck (the machine is outside in a closet) so upon investigation, I've found that when it fills for washing or rinsing, the 'siphon' doesn't seem to empty into the drum quickly enough, and water starts backing up and spills down/out from the detergent tray and runs down the front of the washer. I thought I was using too much detergent, but it does this with plain water, even after several loads. I've tried spraying the siphon out, but no good. Does it need replacing? It is doing it on all cycles, less when I use just cold or hot water, most when I use warm. And NOTHING has changed in the last 3 years... But now I have to sit with it when doing a load and STOP the water fill when I see it running down the front, let it settle, start it again, and, well, this is a royal pain... Suggestions would be most welcome. Ads By Google Related Models |
| Display Modes | |
| Frigidarie Water leaking in ICW make while dispensing water from water dispenser | psanand | Refrigerator & Freezer Repair | 0 | 05-12-2012 06:32 PM |
| Water refilling ice or water dispenser=water spraying in fridge | cheshirekitti | Refrigerator & Freezer Repair | 2 | 01-30-2012 09:28 AM |
| Water Dispener on Whirlpool Fridge Makes Noise and Vibrates Water Line But No Water | ugagrad04 | Refrigerator & Freezer Repair | 0 | 07-20-2010 06:43 PM |
| water dispenser leaks (yes I replaced the water inlet valve, filter, and installed s) | david465 | Refrigerator & Freezer Repair | 4 | 03-11-2010 04:12 PM |
