| » Improper agitating |
Model Number: PAVT234AWW Brand: Maytag Age: 5 - 10 years
The machine is only spinning the load and not moving it up and down. We checked the pump - it's clean. We were advised that the problem can be in transmission or brake. How we can locate the brake? And if we can fix/replace it on our own, do we need special tools for it?
Model PAVT234AWW. Serial # 10303125EC Thanks! Ads By Google Related Models |
The brake would not stop it from agitating. Operate it with the front panel off and see if the motor is turning in the agitation cycle. If it is then the transmission is likely the problem and given the expense of the part of the difficulty of a DIY project and the low cost of a new top loader I suggest replacing it.
__________________
| Display Modes | |
| Improper wire connections new motor | Cumming | Washer Repair | 0 | 05-09-2012 06:38 AM |
| Frigidaire washer improper agitate | jimrox6 | Washer Repair | 2 | 12-17-2011 01:21 PM |
| oven improper shut down. | whittakerrb | Oven Repair (including Ranges and Cooktops) | 0 | 07-04-2011 05:23 PM |
| Improper heating on lower oven | Cobalt20 | Oven Repair (including Ranges and Cooktops) | 0 | 11-30-2010 08:52 AM |
| 30-yr old not agitating | jeweltag | Washer Repair | 9 | 10-18-2010 07:33 AM |
