| » Washing Machine will only complete cycle properly in Gentle Cycle |
Hi.
Please provide the complete model number and brand of the washer. Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I couldn't see the model number without having to move the washer from its position in my upstairs hallway but it is a GE Super Capacity Plus. Hope that helps. If necessary, I will have to try to move it out of its position. Thanks.
Hi.
If the washer completes the Gentle cycle but won't work in the Regular then the most likely it's a bad timer Part number: WH12X10300 Here are the breakdown diagrams and Replacement parts for General Electric S3700E4WW Washer | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Hello. I received the timer part and with the assist of my son-in-law, took off the original and swapped it out with the new. Now the knob assembly is not staying on so that the machine can be turned on to wash. It is free wheeling. When pushing the knob assembly so that it connects to the timer part, it doesn't click into place. The knob free-wheels. I'm thinking I will probably need to replace that unless any of you have a suggested fix attempt.
Hi.
Make sure that the knob, the clip and the dial are not broken. Here is the diagram Controls & backsplash replacement parts for General Electric S3700E4WW Washer | AppliancePartsPros.com Thank you. Simon.
__________________
Thanks Simon for your recommendations. It appears that the swap out of the timer has fixed the issue. The issue with the dial assembly not staying on was due to the timer not being guided into the slots to keep it secured. Once I did that, everything fit perfectly and it is doing its thing. Thanks again. This is a great site!
You are welcome.
Simon.
__________________
| Display Modes | |
| Washing machine doesn't complete its cycle | gusnich | Washer Repair | 0 | 08-26-2010 07:34 AM |
| washing machine stops after agitating cycle, doesn't drain or proceed to next cycle | jjd2009 | Washer Repair | 2 | 11-13-2009 06:31 AM |
| Washing Machine will not complete cycle | Curtis Barnard | Washer Repair | 1 | 10-06-2009 12:32 PM |
| My GE washing machine won't complete cycle | fraizerbaz | Washer Repair | 1 | 07-15-2009 02:36 PM |
| Unable to complete washing cycle | Roger, Portland | Washer Repair | 0 | 02-15-2008 08:00 PM |
