| » leak at water output into tub |
Model Number: GHW9250MW1 Brand: Whirlpool Age: 1 - 5 years
I have a constant leak where the water normally fills the tub just as you open the door on the left side. Can someone tell me what is causing this and what part is needed and how to replace the part?
The water in valve is most likely bad. Remove the top by removing the three screws on the back near the top. Once done you should see the water valve. Clothes Washer Repair Guide
| Display Modes | |
| water leak | mikeg.afs@gmail.com | Washer Repair | 1 | 11-30-2009 03:26 PM |
| water leak in front of refrigerator when using water dispenser | RichardCh | Refrigerator & Freezer Repair | 0 | 08-10-2009 10:29 AM |
| water leak in back from water line | TRUSTART | Refrigerator & Freezer Repair | 1 | 04-05-2009 07:01 AM |
| Water Leak | rlhinze | Washer Repair | 1 | 02-09-2009 02:24 AM |
| Low burner output | bdelaney | Oven Repair (including Ranges and Cooktops) | 1 | 11-03-2008 05:10 PM |
