washer constantly spins out of balance, even after redistributing clothes in tub? can you point me in the right direction?
Hi Robert
You need to inspect the suspension, particularly the springs. Take off the rear access panel.
You can visually inspect the suspension and springs. Even if the springs are not broken you may want to change them out as they can be a problem that is invisible to the ********** eye. You will need a special tool to do this.
Good luck, hope this helps.
