| » washer stops |
Model Number: gts9344ez0 Brand: Whirlpool Age: More than 10 years
my washer stops before the final spin cycle and tub is full of water.when it stops there is a humming noise that lasts for 20 seconds. it sits for a while and resets like an overload switch would,sometimes works sometimes not. i replaced the timer which seemed to help at first but im still having the problem.
Hi.
Please provide the correct model number of the washer. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Remove the drain pump and try without it. Then pull out the motor from the transmission and see if it'll work (you will have to bypass the lid switch). Check the plug at the motor - jiggle the wires a bit. Use the video for disassemble instructions Part number: 285753A Here are the breakdown diagrams and Replacement parts for Whirlpool GST9344EZ0 DIRECT-DRIVE WASHERS | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
| Display Modes | |
| washer stops | lgussler | Washer Repair | 3 | 05-31-2012 04:06 PM |
| Washer Stops | ramtuf9511 | Washer Repair | 7 | 04-01-2009 06:09 PM |
| washer stops | edwin3711 | Washer Repair | 5 | 11-11-2008 02:37 PM |
| Washer Stops spinning | billygrav | Washer Repair | 0 | 04-19-2008 04:04 PM |
| washer stops mid cycle | montani | Washer Repair | 0 | 02-13-2008 06:39 AM |
