Hello,
I have a GE top loader washer (Model # WHDSR315D5WW). Normally, when I push the knob on the front panel, the washer tops and pulling the knob starts the cycle; however, since yesterday the when I push the knob, the water starts filling. Also once the washer completes the cycle the knob does not go back in (i.e., in pushed position) so that I can do a new cycle. Please help!
Thanks, Niket
Groups: APP Team
Hi.
Please provide correct model number. The one you posted is not coming up.
Thank you.
Simon.
Groups: APP Team
Hi Simon - Is there a way I can confirm before I order this expensive part? Is there anything else I can try to see if it works?
Groups: APP Team
Hi.
I am afraid there is no test to confirm it. But you always can return any parts even if they been installed.(If you purchased them from APP).
Simon.
Great. Thanks for the help Simon. I will order the part and post the results after installation.
Groups: APP Team
The part replacement did the trick. Thank you for your help.
Groups: APP Team
