Discuss
Intermittent start, no drain or spin
 in
Washer Repair
Our washer recently either delayed start after lid closed or worked when rapped above control console. Timer motor working, as
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Intermittent start, no drain or spin
  #1 (permalink)
Old 07-14-2012, 12:53 PM
Junior Member
dmontey is on a distinguished road
Default Intermittent start, no drain or spin
Model Number: LWA65AW   Brand: Amana   Age: 5 - 10 years
Our washer recently either delayed start after lid closed or worked when rapped above control console. Timer motor working, as dial advances through different cycles beyon that which is chosen without draining or spinning. Occasional raps on top helped for awhile. Removed top trim and back panel, lid switch continuity OK after repeated actuations. Fill switch seems OK as selected level is appropriate. Extra rinse switch also tests OK. Checked connections at switches, OK. I'm thinking timer, but, it appears very tedious to test each contact. Ideas?
Related Models
Amana LWA65AW WASHER-TOP LOADING
Amana LWA80AL WASHER-TOP LOADING
Amana LWA80AW WASHER-TOP LOADING
Amana LWA90AL WASHER-TOP LOADING
Amana LWA90AW WASHER-TOP LOADING
Amana LWC05AW WASHER-TOP LOADING
Amana LWC07AW WASHER-TOP LOADING
Amana LWC18AW WASHER-TOP LOADING
Amana LWC30AW WASHER-TOP LOADING
Amana LWC40AW WASHER-TOP LOADING
Amana LWC50AW WASHER-TOP LOADING
Amana LWC75AW WASHER-TOP LOADING
Amana LWC80AW WASHER-TOP LOADING
Amana LWC90AW WASHER-TOP LOADING
Amana LWD250 WASHER-TOP LOADING
Amana LWD27AW WASHER-TOP LOADING
Amana LWD27BW WASHER-TOP LOADING
 LWD3081ST Electric Range
Amana LWD352 WASHER-TOP LOADING
Amana LWD352L WASHER-TOP LOADING
Amana LWD352W WASHER-TOP LOADING
Amana LWD353 WASHER-TOP LOADING
Amana LWD353L WASHER-TOP LOADING
Amana LWD353W WASHER-TOP LOADING
Amana LWD35AW WASHER-TOP LOADING
Amana LWD37AW WASHER-TOP LOADING
Amana LWD40AW WASHER-TOP LOADING
Amana LWD450 WASHER-TOP LOADING
Amana LWD453 WASHER-TOP LOADING
Amana LWD553 WASHER-TOP LOADING
Amana LWD553L WASHER-TOP LOADING
Amana LWD553W WASHER-TOP LOADING
Amana LWD650 WASHER-TOP LOADING
Amana LWD662 WASHER-TOP LOADING
Amana LWD67AL WASHER-TOP LOADING
Amana LWD67AW WASHER-TOP LOADING
Amana LWD70AL WASHER-TOP LOADING
Amana LWD70AW WASHER-TOP LOADING
Amana LWD75AW WASHER-TOP LOADING
Amana LWD773 WASHER-TOP LOADING
Amana LWD773L WASHER-TOP LOADING
Amana LWD773W WASHER-TOP LOADING
Amana LWD850 WASHER-TOP LOADING
Amana LWD862 WASHER-TOP LOADING
Amana LWD950 WASHER-TOP LOADING
Amana LWD962 WASHER-TOP LOADING
Amana LWD973 WASHER-TOP LOADING
Amana LWD973L WASHER-TOP LOADING
Amana LWD973W WASHER-TOP LOADING
Amana LWG65AW WASHER-TOP LOADING
 LWHD1000CR Air Conditioner
 LWHD1000R Air Conditioner
 LWHD1006R Air Conditioner
 LWHD1200FR Air Conditioner
 LWHD1200HR Air Conditioner
 LWHD1200R Air Conditioner
 LWHD122FR Air Conditioner
 LWHD1450ER Air Conditioner
 LWHD1500ER Air Conditioner
 LWHD1800R Air Conditioner
 LWHD1807HR Air Conditioner
 LWHD2400HR Air Conditioner
 LWHD2500ER Air Conditioner
 LWHD6500R Air Conditioner
 LWHD6500SR Air Conditioner
 LWHD7000HR Air Conditioner
 LWHD8000RY6 Air Conditioner
 LWHD8008R.AWYAHDP Air Conditioner
Norge LWJ202A WASHER-TOP LOADING
Norge LWJ202H WASHER-TOP LOADING
Norge LWJ202W WASHER-TOP LOADING
Norge LWJ206A WASHER-TOP LOADING
Norge LWJ206H WASHER-TOP LOADING
Norge LWJ206W WASHER-TOP LOADING
Norge LWJ208A WASHER-TOP LOADING
Norge LWJ208H WASHER-TOP LOADING
Norge LWJ208W WASHER-TOP LOADING
Norge LWJ256A WASHER-TOP LOADING
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
motor stops after start of spin/drain cycle jc239 Washer Repair 2 06-02-2011 06:53 AM
Intermittent Drain code problem rhta8702 Washer Repair 4 03-27-2011 10:14 AM
Intermittent drain issue hillsfam Dishwasher Repair 3 07-21-2009 01:49 PM
Maytag Dependble - No Spin/Drain, Motr Hums - Belt Cn Be Rotatd by Hand 2 Start Motor bluestreak Washer Repair 12 12-06-2008 02:53 AM
Spin and pump cycles stop and start, washer won't drain grosshaus Washer Repair 1 03-31-2008 03:10 PM
