| » FH code |
If you look under the top or inside the lower service panel you will find some tech notes that will tell you what the error code means, and will also tell you how to put the machine into a diagnostic mode and do some testing.
Good luck, hope this helps.
__________________
| Display Modes | |
| Duet error code FH and diagnostic code C03 | angelo78 | Washer Repair | 0 | 03-21-2012 08:12 AM |
| F7 Code | markham | Oven Repair (including Ranges and Cooktops) | 1 | 09-02-2011 01:03 PM |
| code f-21 | gearhead41 | Washer Repair | 4 | 07-30-2011 06:10 AM |
| need help with an F 24 code | whsydddy9 | Washer Repair | 1 | 03-07-2011 06:19 PM |
| F5 code | rlb1950 | Oven Repair (including Ranges and Cooktops) | 2 | 11-10-2008 09:52 AM |
