| » Maytag does not rinse/spin |
Model Number: LAT9605aae Brand: Maytag Age: More than 10 years
My washer stopped draining/rinsing/and spinning in the Regular and Permanent cycles. However it works fine in the Delicate cycle. Based on the other posts, I have made sure that door-safety switch is working fine.
In these modes, the timer runs making clicking noise, some times little bigger (relay on/off type) noises. But neither it drains nor spins. If I move it to spin in the Delicates section, it works like a champ. !! Thanks in advance. Ads By Google Related Models |
Hi.
Most likely the timer is bad. Also check if you are getting cold water. The timer Part number: 22001026 Here are the breakdown diagrams and Replacement parts for Maytag LAT9605AAE WASHER-TOP LOADING | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Maytag washer weak spin and rinse | TNTall | Washer Repair | 1 | 02-15-2012 01:00 PM |
| Maytag washer will not spin after the rinse cycle | kempf25 | Washer Repair | 1 | 04-01-2011 07:19 PM |
| Maytag will spin and rinse but not agitate | maytagwashman | Washer Repair | 0 | 03-26-2010 04:21 PM |
| Maytag Washer will not agitate but will spin and rinse | pkbeckman | Washer Repair | 3 | 02-24-2009 02:36 PM |
| Maytag washer won't spin after rinse | path1800 | Washer Repair | 1 | 09-29-2008 01:38 PM |
