| » Maytag Neptune - Spin Suds Lock |
Model Number: MAH5500Bww Brand: Maytag Age: 5 - 10 years
OK, I had the screaming bearing problem and replaced the front and rear drum bearings. Ran the Service Mode - Quick Spin Check, and the machine ran just fine. Topped out around 850 RPM. The problem now is when I run a load of wash, it will operate just fine all the way up the the final spin, but won't spin any faster that about 400 RPM. Then it will set the timer back several minutes, stop spinning and it tries again and again and again, never getting faster than about 400 rpm. No Diagnostic Codes, only Help codes (16 - Spin Suds Lock) and (34 - Too Much Power On Spin). It will spin up to 800 to 850 RPM even with a load of clothes in the test mode, just not in normal mode. Can't find anything in the service manual on how to check or repair the (Spin Suds System), Nothing on the schematics. Any way to correct this problem? ANY IDEAS??? HELP???
And I did check the balance sensors(switches). They tested OK Ads By Google Related Models |
| Display Modes | |
| Maytag Neptune door Lock | Paul F | Washer Repair | 0 | 10-27-2011 01:59 PM |
| LOW-SPIN DURING SPIN CYCLE of MayTag Neptune Dryer/Washer stack | mrdhoffman | Washer Repair | 1 | 08-30-2011 06:45 PM |
| Maytag Neptune Super Stack will not spin while in spin cycle. | Vohn | Washer Repair | 2 | 11-04-2010 08:30 AM |
| "SL" Suds Lock code | gurneyk | Washer Repair | 0 | 09-20-2010 12:59 PM |
| maytag neptune door lock | another mom | Washer Repair | 5 | 07-09-2009 04:50 PM |
