Discuss
Whirlpool Washer- Spin Cycle
 in
Washer Repair
Whirlpool Washer- direct drive (5 to 10 years in age). Everything seem to work properly except spin cycle. Once the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer- Spin Cycle
  #1 (permalink)
Old 01-27-2008, 05:45 AM
dbc dbc is offline
Junior Member
dbc is on a distinguished road
Default Whirlpool Washer- Spin Cycle
Whirlpool Washer- direct drive (5 to 10 years in age). Everything seem to work properly except spin cycle. Once the spin cycle gets to top speed, the tub starts to jump around out of control. Could bad bearings in the tub support cause this?
If the bearing are the problem, I see that a repair kit is available. How hard is it ti replace bearings? Do you have to press them into place? Does the tub support have the bearing included? Would it make moe sense to by the tub support if braeing included?
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer spin cycle ncalvano Washer Repair 4 06-02-2012 05:36 PM
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 10 05-24-2011 12:25 PM
Whirlpool washer spin cycle sporadic? crowes5 Washer Repair 1 09-07-2009 11:16 AM
Whirlpool Washer will not go into spin cycle redstang66 Washer Repair 9 11-06-2008 06:01 AM
Spin Cycle (again) on Whirlpool Washer BCB Washer Repair 2 04-16-2008 06:52 PM
