Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Gray spots on clothes from inside tub drain holes (http://forum.appliancepartspros.com/washer-repair/488439-gray-spots-clothes-inside-tub-drain-holes.html)
Mary Bridget 07-12-2012 11:03 AM
A load of white clothes finished it's wash cycle and I noticed gray stains on the clothes where it was up against the sides of the tub. I pulled the clothes out and the spots matched the drain holes inside the tub. I ran my finger over one of the holes and it left a smear of "gunk" on my finger and the hole. I got a soft brush and brushed around the hole, once it was clean, the hole was actually smaller than it originally looked.
I used the brush around all the holes, which took time to do then I ran a cycle with just hot water and bleached (no clothes)...what was this stuff?
I have not run a load of clothes again, I am not sure if I should clean it with somthing else before I add clothes. And is there a way I can get the stains off the white clothes?
Can you advise?
