My maytag top loader will not spin. It does fill with water and drain ok. I changed the main washer motor, but it does the same, no spin.
What does it do when it should agitate and/or spin?
The information you provided is not enough.
Originally Posted by: Gene What does it do when it should ... spin? You still did not answer on it. Gene.
It has a slow spin and slow agitation. I hear no sounds. When I remove the belt and spin by hand there's no restriction. I've cked the voltage, it's ok, also, drain pump works great.
Could I have put a defected drive motor when retesting? Is there a way to test these motor windings? Your help is greatly appreciated.
I am using a used drive motor. Just maybe I should have purchase a new motor and then done the test..
It is possible. You may want to order the new motor from APP. If it would not fix the problem, you'll be able to return it. - The motor Part number: 661600
Thank you Gene, you're the greatest.
