Discuss
getting the washer apart
 in
Washer Repair
Hi I have a frigidaire gallery model number glws1649as4 and I have taken the screws out of the back then
Appliance Repair Forum > Appliance Repair Help > Washer Repair » getting the washer apart
  #1 (permalink)
Old 09-16-2009, 03:04 PM
Junior Member
Robyn is on a distinguished road
Default getting the washer apart
Brand: Frigidaire   Age: 5 - 10 years
Hi I have a frigidaire gallery model number glws1649as4 and I have taken the screws out of the back then out of the bottom so I could try to take the belt off and get a new one. I cant seem to get any of the panels off to get to anything! I put all teh screws back in until I can figure this out...Help!!
Ads By Google
  #2 (permalink)
Old 09-17-2009, 01:46 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Robyn
I think you need to attack this baby from the top and front, and you also need a service manual.
Here it is.
http://frigidaireservicetips.com/pdfs/489_5.pdf
Let us know how it goes and if you need more info.
good luck
__________________
  #3 (permalink)
Old 09-17-2009, 02:25 PM
Junior Member
Default
Ok I have the top off but cant seem to figure out how to get the front off. Someone told me to lean it against a wall and pull down on the front until it disengages and slides off...can I lay it down to do this?
  #4 (permalink)
Old 09-17-2009, 02:44 PM
Senior Expert
APP Volunteer
Default
There should be two screws at the bottom of the front panel, take them out and the panel should drop down and come off.
__________________
  #5 (permalink)
Old 09-18-2009, 01:44 PM
Junior Member
Default
Ok i just got the front panel off. The belt looks fine from what I can tell. I cant figure out how to take it off. But its all in one piece. any ideas?
  #6 (permalink)
Old 09-18-2009, 01:51 PM
Junior Member
Default
And I just want to add....it tells how to get the belt off...when it says turn off Im assuming you turn it back towards you correct? But it doesnt explain how to get the new one on?
  #7 (permalink)
Old 09-18-2009, 02:09 PM
Senior Expert
APP Volunteer
Default
Disconnect or push in the idler spring and roll or turn the new belt on.
__________________
  #8 (permalink)
Old 09-18-2009, 07:01 PM
Junior Member
Default
sorry to be such a pest. What about if the belt looks good? Could the problem be something else? Or do I want to go ahead and change it?
  #9 (permalink)
Old 09-18-2009, 07:11 PM
Senior Expert
APP Volunteer
Default
You have not told us what the problem is and why you felt you had to replace the belt.
If you can give us a good description of what the washer is doing or not doing then we can probably give you some suggestions.
thanks
__________________
  #10 (permalink)
Old 09-18-2009, 07:36 PM
Junior Member
Default
Well it was whining when it had always been normal...cant remember what else...its been out for 2 months now. I thought I may leave the front off tomorrow and plug it in and turn it on and see exactly what I hear. I do know it would feel up normally I want to say it start when the agitator started moving. I can let u know more tomorrow.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 05:21 PM
is this model number washer a direct drive washer dandjwashington Washer Repair 2 05-01-2009 07:26 PM
Change Washer Lid Switch on Stacked Washer/Dryer scottcomputers Washer Repair 1 05-01-2009 10:16 AM
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 0 11-30-2008 08:35 AM
