Discuss
Washer Control Panel wont come on
 in
Washer Repair
Recently had an error code of LD on my display. I found out that this was the long drain. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Control Panel wont come on
  #1 (permalink)
Old 09-16-2009, 01:41 PM
runninsolo runninsolo is offline
Junior Member
runninsolo is on a distinguished road
Default Washer Control Panel wont come on
Model Number: wtw6200sw2   Brand: Whirlpool   Age: 1 - 5 years
Recently had an error code of LD on my display. I found out that this was the long drain. I checked the impeller and the drain and it was clear.
I did not realize there was a second impeller on the right side. I un did the coupling and there was my issue.
Now I have a secondary issue. During my repairs, I always had my unit unplug. After it was plugged back in, we had a power surge.
Now when I plug in my unit, the display unit is blank no codes, no minute display or any lighting at all.
The unit starts to place water in the tub. The locking mechanism goes through a rotation. Then the unit starts to beep much like when there is an error code or the end of a cycle.
My question is. Does anyone have any advise? I believe the issue is either a machine and motor control board or Control Electric panel. Is there any test or way to narrow down my options to where I dont have to buy both.
Thanks for your time. James
Related Models
Whirlpool WTW6200SW2 Automatic Washer
Whirlpool WTW6200SW3 Automatic Washer
Whirlpool WTW6300SB0 Automatic Washer
Whirlpool WTW6300SB1 Automatic Washer
Whirlpool WTW6300SB2 Automatic Washer
Whirlpool WTW6300SG0 Automatic Washer
Whirlpool WTW6300SG1 Automatic Washer
Whirlpool WTW6300SG2 Automatic Washer
Whirlpool WTW6300SW0 Automatic Washer
Whirlpool WTW6300SW1 Automatic Washer
Whirlpool WTW6300SW2 Automatic Washer
Whirlpool WTW6400SW0 Automatic Washer
Whirlpool WTW6400SW1 Automatic Washer
Whirlpool WTW6400SW2 Automatic Washer
Whirlpool WTW6400SW3 Automatic Washer
Whirlpool WTW6600SB0 Automatic Washer
Whirlpool WTW6600SB1 Automatic Washer
Whirlpool WTW6600SB2 Automatic Washer
Whirlpool WTW6600SB3 Automatic Washer
Whirlpool WTW6600SG0 Automatic Washer
Whirlpool WTW6600SG1 Automatic Washer
Whirlpool WTW6600SG2 Automatic Washer
Whirlpool WTW6600SG3 Automatic Washer
Whirlpool WTW6600SW0 Automatic Washer
Whirlpool WTW6600SW1 Automatic Washer
Whirlpool WTW6600SW2 Automatic Washer
Whirlpool WTW6600SW3 Automatic Washer
Whirlpool WTW6700TW0 Automatic Washer
Bosch WTZ1170
Bosch WTZ1210
Whirlpool WU0800B
Whirlpool WU0800XX0
Whirlpool WU0800XX1
Maytag WU100 Dishwasher - Undercounter
Maytag WU1000 Dishwasher - Undercounter
Whirlpool WU1000X0
Whirlpool WU1000X1
Whirlpool WU1000X4
Whirlpool WU1000X5
Whirlpool WU1000X6
Whirlpool WU1000X7
Whirlpool WU1000X8
Whirlpool WU1000Y0
Whirlpool WU1000Y1
Maytag WU1004 Dishwasher - Undercounter
Maytag WU1005 Dishwasher - Undercounter
Maytag WU101 Dishwasher - Undercounter
Maytag WU103 Dishwasher - Undercounter
Maytag WU104 Dishwasher - Undercounter
Maytag WU180 Dishwasher - Undercounter
Whirlpool WU1800XX0
Frigidaire WU180T1BLACK Wwh(v5) / 18 " Dishwasher
Frigidaire WU180TF1 Wwh(v3) / 18 " Dishwasher
Frigidaire WU180TH1 Wwh(v2) / 18 " Dishwasher
Frigidaire WU180TR1 Wwh(v1) / 18 " Dishwasher
Frigidaire WU180TV1 Wwh(v4) / 18 " Dishwasher
Frigidaire WU180TW1 Wwh(v6) / 18 " Dishwasher
Maytag WU181 Dishwasher - Undercounter
Maytag WU200 Dishwasher - Undercounter
Maytag WU201 Dishwasher - Undercounter
Maytag WU202 Dishwasher - Undercounter
Maytag WU203 Dishwasher - Undercounter
Maytag WU204 Dishwasher - Undercounter
Maytag WU282 Dishwasher - Undercounter
Maytag WU284 Dishwasher - Undercounter
Maytag WU285 Dishwasher - Undercounter
Maytag WU300 Dishwasher - Undercounter
Whirlpool WU3000V0
Whirlpool WU3000V1
Whirlpool WU3000V2
Whirlpool WU3000V3
Whirlpool WU3000X0
Whirlpool WU3000X1
Whirlpool WU3000X2
Whirlpool WU3000X3
Whirlpool WU3000X4
Whirlpool WU3000X5
Whirlpool WU3000X6
Whirlpool WU3000Y0
Whirlpool WU3000Y1
Whirlpool WU3006V0
Whirlpool WU3006V1
Whirlpool WU3006V2
Whirlpool WU3006V3
Whirlpool WU3006X0
Whirlpool WU3006X1
Whirlpool WU3006X2
Whirlpool WU3006X3
Whirlpool WU3006X4
Whirlpool WU3006X5
Whirlpool WU3006X6
Whirlpool WU3006Y0
Whirlpool WU3006Y1
Maytag WU301 Dishwasher - Undercounter
Maytag WU302 Dishwasher - Undercounter
Maytag WU303 Dishwasher - Undercounter
Maytag WU304 Dishwasher - Undercounter
Whirlpool WU3050Y0
Whirlpool WU3050Y1
Whirlpool WU3056Y0
Whirlpool WU3056Y1
Maytag WU384 Dishwasher - Undercounter
Maytag WU400 Dishwasher - Undercounter
Maytag WU401 Dishwasher - Undercounter
Maytag WU404 Dishwasher - Undercounter
Whirlpool WU4300B0
Whirlpool WU4300B1
Whirlpool WU4300Y0
Whirlpool WU4300Y1
Whirlpool WU4300Y2
Whirlpool WU4300Y3
Whirlpool WU4300Y4
Whirlpool WU4400V0
Whirlpool WU4400V1
Whirlpool WU4400V2
Whirlpool WU4400V3
Whirlpool WU4400X0
Whirlpool WU4400X1
Whirlpool WU4400X2
Whirlpool WU4406V1
  #2 (permalink)
Old 09-17-2009, 01:38 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Hi James
The irony and dilemma here is that whatever we can do to troubleshoot this involves the display, and since your display is not working there does not appear any way to test things out.
It is likely your control board is the problem since the machine will start up, but the only way to check it is to replace it.
Here is the service manual, so that if you can get it going and still have problems you can do further diagnostics.
https://secured.whirlpool.com/Servic...LE/8178583.pdf
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
samsung washer control panel drwibble Dishwasher Repair 0 10-11-2009 02:59 AM
GE Oven Start button on Control Panel wont work JAUGUSTINE Oven Repair (including Ranges and Cooktops) 1 07-06-2009 02:42 PM
washer control panel the general Washer Repair 1 06-12-2009 10:20 AM
tranformer blew on control panel need specs for new transformer not control panel kaydog2009 Oven Repair (including Ranges and Cooktops) 0 05-11-2009 07:22 AM
GE Washer Control Panel Beeps rplageman Washer Repair 0 03-01-2008 07:03 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
