Discuss
washer
 in
Washer Repair
washer is not spinning when draining. put in new timer and still not working. i can push on/off and it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer
  #1 (permalink)
Old 07-10-2012, 08:29 AM
Junior Member
walley is on a distinguished road
Default washer
Model Number: 22722100   Brand: Kenmore   Age: More than 10 years
washer is not spinning when draining. put in new timer and still not working. i can push on/off and it will kick in and spin. took door switch out and wired together to eliminate that. Help!
Ads By Google
Related Models
Amana 2274.000 Mwave - Family Size (60 Hz)
Amana 2274.001 Mwave - Family Size (60 Hz)
Amana 2274.A Mwave - Family Size (60 Hz)
Whirlpool 2275W0A
Whirlpool 2275^0A
Amana 2276.A Mwave - Family Size (60 Hz)
Whirlpool 2276W1A
Whirlpool 2276^1A
Jenn-Air 2280EEL Walloven - Std Ele
Jenn-Air 2281EEL Walloven - Std Ele
Magic Chef 22F-6KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22FA-2KLW Range - Cont Clean Dbl Oven Gas
Magic Chef 22FA-2KW Walloven - Std Dbl Oven Gas
Magic Chef 22FA-6CKLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22FA-6KLX Range - Cont Clean Dbl Oven Gas
Magic Chef 22FA-6KLX-6F Range - Cont Clean Dbl Oven Gas
Magic Chef 22FA-6KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22FK-2KLW Range - Cont Clean Dbl Oven Gas
Magic Chef 22FK-2KW Walloven - Std Dbl Oven Gas
Magic Chef 22FK-6KLX Range - Cont Clean Dbl Oven Gas
Magic Chef 22FK-6KLX-6F Range - Cont Clean Dbl Oven Gas
Magic Chef 22FK-6KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22FN-2KLW Range - Cont Clean Dbl Oven Gas
Magic Chef 22FN-2KW Walloven - Std Dbl Oven Gas
Magic Chef 22FN-6CKLXV8
Magic Chef 22FN-6KLX Range - Cont Clean Dbl Oven Gas
Magic Chef 22FN-6KLX-6F Range - Cont Clean Dbl Oven Gas
Magic Chef 22FN-6KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22FY-2KLW Range - Cont Clean Dbl Oven Gas
Magic Chef 22FY-2KW Walloven - Std Dbl Oven Gas
Magic Chef 22FY-6KLX Range - Cont Clean Dbl Oven Gas
Magic Chef 22FY-6KLX-6F Range - Cont Clean Dbl Oven Gas
Magic Chef 22FY-6KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22J-7KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22JA-7KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22JK-7KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22JN-7KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22JY-7KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22M-7KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22MA-7KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22MN-7KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22MW-7KLXV8 Range - Cont Clean Mwave Gas
Magic Chef 22RA-3B-49 Rv Range - Gas
Magic Chef 22RA-3BKZ Rv Range - Gas
Magic Chef 22RA-3BTZ Rv Range - Gas
Magic Chef 22RA-3BZ Rv Range - Gas
Magic Chef 22RA-4 Rv Range - Gas
Magic Chef 22RA-4K Rv Range - Gas
Magic Chef 22RA-4K-49 Rv Range - Gas
Magic Chef 22RA-4KVX Rv Range - Gas
Magic Chef 22RA-4KX Rv Range - Gas
Magic Chef 22RA-4KZ Rv Range - Gas
Magic Chef 22RA-4T Rv Range - Gas
Magic Chef 22RA-4TVX Rv Range - Gas
Magic Chef 22RA-4TX Rv Range - Gas
Magic Chef 22RA-4TZ Rv Range - Gas
Magic Chef 22RB-3B Rv Range - Gas
Magic Chef 22RB-3BKZ Rv Range - Gas
Magic Chef 22RB-3BTVX Rv Range - Gas
Magic Chef 22RB-3BTZ Rv Range - Gas
Magic Chef 22RB-3BZ Rv Range - Gas
Magic Chef 22RB-4 Rv Range - Gas
Magic Chef 22RB-4K Rv Range - Gas
Magic Chef 22RB-4KVX Rv Range - Gas
Magic Chef 22RB-4KX Rv Range - Gas
Magic Chef 22RB-4KZ Rv Range - Gas
Magic Chef 22RB-4T Rv Range - Gas
Magic Chef 22RB-4TVX Rv Range - Gas
Magic Chef 22RB-4TX Rv Range - Gas
Magic Chef 22RB-4TZ Rv Range - Gas
Magic Chef 22RS-4 Rv Range - Gas
Magic Chef 22RS-4K Rv Range - Gas
Magic Chef 22RS-4KVX Rv Range - Gas
Magic Chef 22RS-4KX Rv Range - Gas
Magic Chef 22RS-4KZ Rv Range - Gas
Magic Chef 22RS-4T Rv Range - Gas
Magic Chef 22RS-4TVX Rv Range - Gas
Magic Chef 22RS-4TX Rv Range - Gas
Magic Chef 22RS-4TZ Rv Range - Gas
Magic Chef 22RW-3B-49 Rv Range - Gas
Magic Chef 22RW-3BK Rv Range - Gas
Magic Chef 22RW-3BK49 Rv Range - Gas
Magic Chef 22RW-3BKZ Rv Range - Gas
Magic Chef 22RW-3BTVX Rv Range - Gas
Magic Chef 22RW-3BTZ Rv Range - Gas
Magic Chef 22RW-3BZ Rv Range - Gas
Magic Chef 22RW-4 Rv Range - Gas
Magic Chef 22RW-4K Rv Range - Gas
Magic Chef 22RW-4K-49 Rv Range - Gas
Magic Chef 22RW-4KVX Rv Range - Gas
Magic Chef 22RW-4KX Rv Range - Gas
Magic Chef 22RW-4KZ Rv Range - Gas
Magic Chef 22RW-4T Rv Range - Gas
Magic Chef 22RW-4TVX Rv Range - Gas
Magic Chef 22RW-4TX Rv Range - Gas
Magic Chef 22RW-4TZ Rv Range - Gas
Magic Chef 22TA-3BKZ Rv Range - Gas
Magic Chef 22TA-3BZ Rv Range - Gas
Magic Chef 22TA-4-49 Rv Range - Gas
Magic Chef 22TA-4KZ Rv Range - Gas
Magic Chef 22TA-4Z Rv Range - Gas
Magic Chef 22TB-3B Rv Range - Gas
Magic Chef 22TB-3BKZ Rv Range - Gas
Magic Chef 22TB-3BZ Rv Range - Gas
Magic Chef 22TW-3B-49 Rv Range - Gas
Magic Chef 22TW-3BK Rv Range - Gas
Magic Chef 22TW-3BK49 Rv Range - Gas
Magic Chef 22TW-3BKE Rv Range - Gas
Magic Chef 22TW-3BKZ Rv Range - Gas
Magic Chef 22TW-3BZ Rv Range - Gas
Magic Chef 22TW-4KZ Rv Range - Gas
Jenn-Air 2300 Surface Unit - Ddraft Ele
Jenn-Air 2300ERS Surface Unit - Ddraft Ele
Jenn-Air 23075 Surface Unit - Gas
Jenn-Air 23079 Surface Unit - Gas
Jenn-Air 2320ERS Surface Unit - Ddraft Ele
Whirlpool 2323W0A
Whirlpool 2323^0A
Whirlpool 2324W0A
Jenn-Air 2325ERS Surface Unit - Ddraft Ele
  #2 (permalink)
Old 07-10-2012, 09:55 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
What is the complete model number?
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 07-10-2012, 06:39 PM
Junior Member
Default washer
model # 100.22722110
  #4 (permalink)
Old 07-10-2012, 08:58 PM
Expert
Default
Hi.
Why did you bypass the lid switch? Did it make any difference?
This washer is equipped with "neutral drain transmission", witch means that washer first draining the water out then timer pausing for a few seconds allowing transmission gears to engage. When the motor restarts - the basket start spinning.
Check if the timer makes a brief stop when it's draining.
If it's not pausing - bad timer.
Thank you.
Simon.
__________________
  #5 (permalink)
Old 07-10-2012, 09:53 PM
Junior Member
Default washer
Will check that. I just replaced timer with new from you guys. It is better than with old timer. Thanks, will let you know
  #6 (permalink)
Old 07-11-2012, 09:56 AM
Expert
Default
You are welcome.
Simon.
__________________
  #7 (permalink)
Old 07-14-2012, 11:18 AM
Junior Member
Default washer
Simon, washer paused for 3 seconds then kicked to spin but didn't stay engaged. Shut off and turned right back on and started to spin and drain. Same after rinse cycle.
  #8 (permalink)
Old 07-16-2012, 10:07 AM
Expert
Default
Hi.
Does the washer spin and drain? Does the laundry ready for the dryer at the end of the wash?
Do you still have the lid switch bypassed?
Simon.
__________________
  #9 (permalink)
Old 07-16-2012, 08:19 PM
Junior Member
Default washer
Yes, it will spin and drain. It doesn't spin after wash or rinse unless I push timer off then on. Will spin at end of cycle. I do still have lid switch by passed.
  #10 (permalink)
Old 07-17-2012, 01:47 PM
Expert
Default
Hi.
Please double check the model number and post the timer part number that you replaced.
Thank you.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
