Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   washer (http://forum.appliancepartspros.com/washer-repair/487878-washer.html)
walley 07-10-2012 08:29 AM
washer
washer is not spinning when draining. put in new timer and still not working. i can push on/off and it will kick in and spin. took door switch out and wired together to eliminate that. Help!
Simon / APP Team 07-10-2012 09:55 AM
Hi.
What is the complete model number?
Simon.
walley 07-10-2012 06:39 PM
washer
model # 100.22722110
Simon / APP Team 07-10-2012 08:58 PM
Hi.
Why did you bypass the lid switch? Did it make any difference?
This washer is equipped with "neutral drain transmission", witch means that washer first draining the water out then timer pausing for a few seconds allowing transmission gears to engage. When the motor restarts - the basket start spinning.
Check if the timer makes a brief stop when it's draining.
If it's not pausing - bad timer.
Thank you.
Simon.
walley 07-10-2012 09:53 PM
washer
Will check that. I just replaced timer with new from you guys. It is better than with old timer. Thanks, will let you know
Simon / APP Team 07-11-2012 09:56 AM
You are welcome.
Simon.
walley 07-14-2012 11:18 AM
washer
Simon, washer paused for 3 seconds then kicked to spin but didn't stay engaged. Shut off and turned right back on and started to spin and drain. Same after rinse cycle.
Simon / APP Team 07-16-2012 10:07 AM
Hi.
Does the washer spin and drain? Does the laundry ready for the dryer at the end of the wash?
Do you still have the lid switch bypassed?
Simon.
walley 07-16-2012 08:19 PM
washer
Yes, it will spin and drain. It doesn't spin after wash or rinse unless I push timer off then on. Will spin at end of cycle. I do still have lid switch by passed.
Simon / APP Team 07-17-2012 01:47 PM
Hi.
Please double check the model number and post the timer part number that you replaced.
Thank you.
Simon.
