Discuss
Top load washer quit spinning
 in
Washer Repair
Last night the washer stopped spinning.. it goes thru all the cycles- fills and drains. but the basket doesnt move..
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Top load washer quit spinning
  #1 (permalink)
Old 09-16-2009, 08:29 AM
Junior Member
catmorgn is on a distinguished road
Default Top load washer quit spinning
Brand: Kenmore   Age: More than 10 years
Last night the washer stopped spinning.. it goes thru all the cycles- fills and drains. but the basket doesnt move.. therefore the clothes are very very wet.
Machine is more than 10 yrs old. Never have had a service call on it. Is this an inexpensive fix or should I start looking for new machine? I dont have problem fixing machine- if the cost will be quite a bit less than new machine.. Any suggestions?
Ads By Google
  #2 (permalink)
Old 09-16-2009, 11:41 AM
Senior Member
applianceman is on a distinguished road
Default
Kenmore appliances are made by lots of companies need model number to know that you have. Clothes Washer Repair Guide
  #3 (permalink)
Old 09-16-2009, 11:53 AM
Junior Member
Default
Quote:
It says Kenmore- Heavy Duty 60 Series.. I bought it at Sears. I will have to go home to check more... dont know if this helps
  #4 (permalink)
Old 09-16-2009, 05:02 PM
Senior Member
Default
Well Whirlpool makes most Kenmore washers but I hate to answer about Whirlpool and it turns out to be something else. We always need the model number especially on Kenmore. The model number should be near or in the lid.
  #5 (permalink)
Old 09-17-2009, 07:43 AM
Junior Member
Default Model Number
Ok,
I found the model etc.. it said Model # 110. 92260100
Serial # CC0221372
Does that help?
  #6 (permalink)
Old 09-17-2009, 09:40 AM
Senior Member
Default
Ok it is made by whirlpool. The coupling is most likely broken this page will describe how to remove the motor http://www.appliance-repair-it.com/Whirlpool-washer-disassembly.html Once the motor is removed you can access the coupling.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Top load Direct Drive Kenmore not spinning pharmadennis Washer Repair 12 04-14-2010 02:35 PM
Top load washer not spinning smytha Washer Repair 1 11-11-2009 03:07 AM
washer quit spinning, motor still hums sunshine61 Washer Repair 2 02-16-2009 04:48 PM
Frigidaire Top Load Washer Squeals When Spinning tgbowler Washer Repair 0 07-27-2008 08:59 AM
maytag neptune frt load not spinning between cycles kimmysue Washer Repair 0 06-08-2008 08:15 AM
