| » washer problem |
Quote:
If it's draining the water out as it's filling, without the motor running, it's setting up a siphon. Make sure your drain hose is higher then the top of the tub. Your drain hose should fit loosely enough in the standpipe so air can enter. Or the fitting on the end of the hose should have the ability to allow air to enter.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| How to fix washer simple looking problem with washer | Woltato | Washer Repair | 1 | 09-20-2009 07:21 AM |
| washer problem | herkyfred | Washer Repair | 3 | 05-25-2009 04:21 PM |
| Re: Washer Problem | herkyfred | Dryer Repair | 1 | 05-18-2009 05:11 PM |
| washer problem | resta | Washer Repair | 3 | 05-08-2009 01:58 PM |
| Washer problem in LARGE load setting- timer problem? | jagtianis | Washer Repair | 9 | 08-04-2008 02:49 AM |
