gwsavoie
#1 Posted : Wednesday, September 16, 2009 5:19:55 AM(UTC)
gwsavoie
Washer won't spin all other cycle work good. Washer will spin if I manually start turning the tub.
#2 Posted : Wednesday, September 16, 2009 3:31:19 PM(UTC)
What is the complete model number of the washer?
gwsavoie
#3 Posted : Wednesday, September 16, 2009 3:38:04 PM(UTC)
gwsavoie
don't need anymore exaggrevation when out and got a new machine
Thank you for you reply
Edwardritchy
#4 Posted : Wednesday, September 16, 2009 4:15:45 PM(UTC)
Edwardritchy
Hi Gene:
I have a 2000 Maytag model number LAT9420AAE Serial 10470402YK.
At firat the washer was making a noise and I smelled some buring rubberso I shut it down. The washer would not agatate or spin but the motor would run.
The belts were loose so I replaced them but that cured nothing.
I next thought the transmission went bad and Maytag sent me a new transmission.
The washer now will agatate both when it should while washing and also when it is in the spin cycle. It will pump out the water but it will not spin out.
I am not sure if the motor is suspose to reverse itself to spin out but it only goes one way.
I am stumped HELPPPPPP........Please
Thanks for volunteering and for any help you can give me Gene.
Ed
#5 Posted : Thursday, September 17, 2009 2:38:12 PM(UTC)
Hi Ed,
The motor is reversible and should rotate in different directions for agitation and spin. The problem most likely is a bad timer.
- The timer Part number: AP4029051
Here are the breakdown diagrams and replacement parts for the Maytag washer Model LAT9420AAE
Kenmore 110.47566601 makes loud spin noise (Washer Repair)
by Guest 4/6/2024 7:42:40 PM(UTC)
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Shaking while spinning (Washer Repair)
by Guest 3/20/2024 8:39:31 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
Maytag Bravos clicking when filling, wash plate spins fast afterward (Washer Repair)
by nsar24 3/3/2024 9:34:39 AM(UTC)
GE Frontload Washer Spin (Washer Repair)
by mahgnibb 2/16/2024 6:13:51 AM(UTC)
Samsung Washer No Agitation or Spin (Washer Repair)
by amappliancewi 2/7/2024 10:24:03 AM(UTC)
Frigidaire Front Load Washer only spins fast (Washer Repair)
by Guest 2/6/2024 12:15:55 PM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag high pitch squeal during spin (Washer Repair)
by Guest 2/1/2024 4:09:33 PM(UTC)
Slow agitation and spin with clicking noise in bottom end of machine (Washer Repair)
by Guest 1/13/2024 12:19:08 AM(UTC)
Washer not agitating, spinning or draining. (Washer Repair)
by Guest 12/28/2023 2:09:09 PM(UTC)
