Discuss
top loading washer suspension rods and tub
 in
Washer Repair
i dont konw the age however when the tub fills with water the tub will drop down and rub in
Appliance Repair Forum > Appliance Repair Help > Washer Repair » top loading washer suspension rods and tub
  #1 (permalink)
Old 01-26-2008, 02:51 PM
Junior Member
madisonrose05 is on a distinguished road
Default top loading washer suspension rods and tub
Brand: GE   Age: 1 - 5 years
i dont konw the age
however when the tub fills with water the tub will drop down and rub in the bottom of the floor pan. it seems there are suppost to be two shock absorbers/suspension rods that are on either side of the tub bracket laterally, (not the for rods running vertically). is it possible these are missing? i cant find any info as far as parts
thanks
kevin
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Top Support Rods came out :( MedicRN Oven Repair (including Ranges and Cooktops) 8 12-06-2009 03:27 PM
top loading GE washer faststart Washer Repair 1 07-01-2009 06:21 AM
GE Top loading washer won't drain jacoblag Washer Repair 3 01-24-2009 04:05 PM
GE top loading washer not draining cpope24 Washer Repair 2 07-21-2008 08:15 AM
GE Top Loading washer Mike Miller Washer Repair 3 02-05-2008 05:57 PM
