Discuss
Maytag washer leaks out the bottom?
 in
Washer Repair
When the washer is filled above small load size, it begins to leak out of the bottom. I took the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer leaks out the bottom?
  #1 (permalink)
Old 07-08-2012, 10:43 AM
Junior Member
Mdan is on a distinguished road
Default Maytag washer leaks out the bottom?
Model Number: sav515daww   Brand: Maytag   Age: 1 - 5 years
When the washer is filled above small load size, it begins to leak out of the bottom. I took the cover off, and the leak is coming from the bottom center of the drum, just below the center of a plastic fan looking thing, and it is leaking on top of a cast metal disc, looks it is leaking from a black seal between the two. How do I fix it?
The unit is a Maytag HD legacy series, commercial quality unit, real fancy, lots of dials.
Thanks, Dan
Related Models
Maytag SAV515DAWW WASHER-TOP LOADING
Maytag SAV515DEWW WASHER-TOP LOADING
Maytag SAV5300AWW WASHER-TOP LOADING
Maytag SAV5401AWW WASHER-TOP LOADING
Maytag SAV5600AWW WASHER-TOP LOADING
Maytag SAV5701AWQ WASHER-TOP LOADING
Maytag SAV5701AWW WASHER-TOP LOADING
Maytag SAV5710AWW WASHER-TOP LOADING
Maytag SAV571EEWW WASHER-TOP LOADING
Maytag SAV5910AWW WASHER-TOP LOADING
Maytag SAV5910EWW WASHER-TOP LOADING
Maytag SAW25K3S WASHER-TOP LOADING
Whirlpool SAWB600HQ0 AUTOMATIC WASHER
Whirlpool SAWB600JQ0 WASHER
Whirlpool SAWB600JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800HQ0 AUTOMATIC WASHER
Whirlpool SAWS800JQ0 WASHER
Whirlpool SAWS800JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800JQ2 WASHER
Whirlpool SAWS800MQ0 AUTOMATIC WASHER
Whirlpool SAWS900HQ0 WASHER
Whirlpool SAWS900JQ0 WASHER - DIRECT DRIVE
Whirlpool SAWS900MQ0 AUTOMATIC WASHER
Whirlpool SAWX650JQ0 WASHER
Whirlpool SAWX650MQ0 AUTOMATIC WASHER
Whirlpool SAWX650MQ2 AUTOMATIC WASHER
Whirlpool SB1000SKN0 BUILT-IN GAS OVEN
Whirlpool SB100PEDB0 24" GAS BUILT-IN OVEN STANDARD CLEAN
Whirlpool SB100PEDB1 24" GAS BUILT-IN STANDARD CLEAN OVEN
Whirlpool SB100PEDB2 24" GAS BUILT-IN-OVEN STANDARD CLEAN
Whirlpool SB100PEDB4 GAS RANGE AND OVEN
Whirlpool SB100PEDB5 24" GAS SLIDE-IN RANGE
Whirlpool SB100PEK1 BUILT-IN GAS OVEN
Whirlpool SB100PER0 Range (gas)*
Whirlpool SB100PES0 Range (gas)*
Whirlpool SB100PES1 Range (gas)*
Whirlpool SB100PES2 Range (gas)*
Whirlpool SB100PES3 Range (gas)*
Whirlpool SB100PES4 GAS RANGES & OVENS
Whirlpool SB100PSK0 BUILT-IN GAS OVEN
Whirlpool SB100PSK1 BUILT-IN GAS OVEN
Whirlpool SB100PSR0 Range (gas)*
Whirlpool SB100PSR1 Range (gas)*
Whirlpool SB130PEDB0 24" GAS BUILT-IN OVEN CONTINUOUS CLEAN
Whirlpool SB130PEDB1 24" GAS BUILT-IN CONTINUOUS CLEAN OVEN
Whirlpool SB130PEDB2 24" GAS BUILT-IN-OVEN CONTINUOUS CLEAN
Whirlpool SB130PEK0 BUILT-IN GAS OVEN
Whirlpool SB130PER1 Range (gas)*
Whirlpool SB130PER2 Range (gas)*
Whirlpool SB130PER3 Range (gas)*
Whirlpool SB130PER4 GAS BUILT-IN OVEN
Whirlpool SB130PER5 24" GAS BUILT-IN OVEN ELECTRONIC IGNITION CONTINUOUS CLEAN OVEN
Whirlpool SB130PERW0 Range (gas)*
Whirlpool SB130PSK0 BUILT-IN GAS OVEN
Whirlpool SB160PEDB0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB2 24" BUILT-IN-OVEN
Whirlpool SB160PEDB4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ2 24" BUILT-IN-OVEN
Whirlpool SB160PEDQ4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEEB1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEB2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEB5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEB6 BUILT-IN GAS OVEN
Whirlpool SB160PEEB7 BUILT-IN GAS OVEN
Whirlpool SB160PEEB8 BUILT-IN GAS OVEN
Whirlpool SB160PEEB9 BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEQ2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEQ6 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ7 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ8 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ9 BUILT-IN OVEN, GAS
Whirlpool SB160PEXB0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ1 BUILT IN GAS OVEN
Amana SB21VE REF - SXS/I&W
Amana SB21VPSE REF - SXS/I&W
Amana SB21VW REF - SXS/I&W
Thermador SB2B
Amana SB520K REF - SXS/I&W
Amana SB520SW REF - SXS/I&W
Amana SB520TW REF - SXS/I&W
Amana SBC24FX0 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FX5 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FXOW RANGE - ELECTRIC STD DELAWARE
Amana SBC26CK RANGE - ELECTRIC STD DELAWARE
Amana SBD20H REF - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K REF - SXS/I&W
Amana SBD20M REF - SXS/I&W
Amana SBD20MW REF - SXS/I&W
Amana SBD20NE REF - SXS/I&W
Amana SBD20NW REF - SXS/I&W
Amana SBD20Q2E REF - SXS/I&W
Amana SBD20Q2W REF - SXS/I&W
Amana SBD20S4E REF - SXS/I&W
Amana SBD20S4L REF - SXS/I&W
Amana SBD20S4W REF - SXS/I&W
Amana SBD20TPE REF - SXS/I&W
Amana SBD20TPL REF - SXS/I&W
Amana SBD20TPSW REF - SXS/I&W
Amana SBD20TPW REF - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Atlantis water leak.Seems it leaks from bottom or side of plastic tub.Nee help wendelg Washer Repair 4 01-22-2017 04:31 PM
GE washer leaks from bottom esabin Washer Repair 1 10-28-2011 04:05 PM
Maytag dishwasher leaks from bottom gasket susanjay Dishwasher Repair 0 04-08-2011 12:31 PM
Maytag Washer leaks at bottom ronf Washer Repair 1 10-23-2010 05:37 PM
washer leaks from bottom pgreen1017 Washer Repair 1 12-12-2009 06:39 PM
