Replaced door seal (boot) with part number WH45X10062.
Installation seemed to go smoothly. However, it now makes noise like rubber is rubbing while spinning, i.e., motor-driven. When spun by hand, does not make the noise.
Extra info: Followed written instructions and leaned machine back about 8 inches to do repair.
Thanks for any help!
Hard to say what the problem is, it may fix itself over time. In the meantime you may want to rub some liquid soap detergent on the outside of the gasket and see if that stops the noise.
