| » Oasis kenmore code F 50 appeared |
Here is the tech sheet
https://www.servicematters.com/docs/...%208567037.pdf
__________________
Performed all the test and have found and narrowed it down to the RPS (rotor posituion sensor) However, I need to get underneath the washer.
How can I empty the tub manually so I can lean it on it's side to gain access to the RPS? Hopefully, wires just came loose or disconnected. Or might have to replace the RPS. Or, just leaning it to it's side and let the water just drain out away from the electrical control panel. I was just wondering if there was a drain plug in the bottom of the tub or someother proper procedure in doing so. Thanks....... Quote:
From what I understand the Oasis is a close match to a Whirlpool Cabio so here is a service manual for a Cabrio
https://secured.whirlpool.com/Servic...LE/8178582.pdf On most units if you get the drain hose lower than the tub, it will drain. Looks like this is not possible on this unit. You may have to bail it out or try siphoning it out.
__________________
Found that my RPS burnt and found a burnt wire in the stator.
I have tried to search for this stator on the web but unabe to find it. Found lots of parts to this machine, but does not list a stator. Is this stator part still available to buy? Kenmore Elite Oasis washer model # 110.27052601 Found it to be manufactued by whirlpool. Thanks...... Quote:
| Display Modes | |
| Kenmore Oasis F1 Code | Vacy72 | Washer Repair | 8 | 01-03-2012 09:05 AM |
| F1 code Kenmore elite oasis toploading washer | JuliaD | Washer Repair | 1 | 11-17-2009 04:48 PM |
| kenmore oasis he fault code F50 | end of the road gang | Washer Repair | 2 | 09-14-2009 10:21 AM |
| kenmore oasis he fault code F50 | end of the road gang | Washer Repair | 0 | 09-13-2009 05:49 AM |
| Kenmore Oasis Code F-54 | richmond418 | Washer Repair | 3 | 05-04-2009 09:27 AM |
