Discuss
Water always HOT
 in
Washer Repair
As for age, it came with the house. Think I'm beginning to understand why they left it. Other than the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water always HOT
  #1 (permalink)
Old 07-06-2012, 11:51 AM
Junior Member
malinst is on a distinguished road
Default Water always HOT
Model Number: MAV7650AWW   Brand: Maytag   Age: 5 - 10 years
As for age, it came with the house. Think I'm beginning to understand why they left it. Other than the water being HOT all the time, it's a nice stainless washer.
Okay, so even in the COLD/COLD setting NON ATC the ATC light is on and the water is very warm. To test if hot water getting to washer on the cold setting, I turned off the hot supply entirely. ran a test fill and it was very cold. then i began to turn the hot back on and the test water got hot/very warm. not as hot as hot only, but very warm, way over 100 degrees.
What do you think it could most likely be and what fix would you recommend?
since both hot and cold flow freely, I don't think it's a valve problem. Is there a controller or something that sounds like the problem? Especially how the ATC light is always on.
Thanks in advance!! You might just save my marriage :-)
Ads By Google
Related Models
Maytag MAV7650AWW Washer, Atlantis
Maytag MAV7657EWQ Washer, Atlantis
Maytag MAV7657EWW Washer, Atlantis
Maytag MAV7700AWQ Washer, Atlantis
Maytag MAV7700AWW Washer, Atlantis
International MAV7750AGW Washer - Top Loading
International MAV7750BGW Washer - Top Loading
International MAV7750CGW Washer - Top Loading
Maytag MAV7757AWQ Washer, Atlantis
Maytag MAV7757AWW Washer, Atlantis
Maytag MAV8000AWQ Washer, Atlantis
Maytag MAV8000AWW Washer, Atlantis
Maytag MAV8057AWQ Washer, Atlantis
Maytag MAV8057AWW Washer, Atlantis
Maytag MAV8260AWQ Washer, Atlantis
Maytag MAV8260AWW Washer, Atlantis
Maytag MAV8500AWA Washer, Atlantis
Maytag MAV8500AWQ Washer, Atlantis
Maytag MAV8500AWW Washer, Atlantis
Maytag MAV8551AWQ Washer, Atlantis
Maytag MAV8551AWW Washer, Atlantis
Maytag MAV8557AWQ Washer, Atlantis
Maytag MAV8557AWW Washer, Atlantis
Maytag MAV8600AWQ Washer, Atlantis
Maytag MAV8600AWW Washer, Atlantis
Maytag MAV8601AWQ Washer, Atlantis
Maytag MAV8601AWW Washer, Atlantis
Maytag MAV8757AWQ Washer, Atlantis
Maytag MAV8757AWW Washer, Atlantis
Maytag MAV9501EWQ Washer, Atlantis
Maytag MAV9501EWW Washer, Atlantis
Maytag MAV9504EWQ Washer, Atlantis
Maytag MAV9504EWW Washer, Atlantis
Maytag MAV9557EWQ Washer, Atlantis
Maytag MAV9557EWW Washer, Atlantis
Maytag MAV9600EWQ Washer, Atlantis
Maytag MAV9600EWW Washer, Atlantis
Maytag MAV9657EWQ Washer, Atlantis
Maytag MAV9657EWW Washer, Atlantis
Maytag MAV9750AGW Washer, Atlantis
Maytag MAV9750AWQ Washer, Atlantis
Maytag MAV9750AWW Washer, Atlantis
Maytag MAVT236AWW Washer - Top Loading
Maytag MAVT346AWW Washer - Top Loading
Maytag MAVT446AWW Washer - Top Loading
Maytag MAVT546EWW Washer - Top Loading
Maytag MAVT634AWW Washer, Atlantis
Maytag MAVT734EWW Washer, Atlantis
Maytag MAVT754EWW Washer, Atlantis
Maytag MAVT834AWQ Washer, Atlantis
Maytag MAVT834AWW Washer, Atlantis
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
International MB2227PEHB  Ref - Maytag Int'l Bot Mount
International MB2227PEHW  Ref - Maytag Int'l Bot Mount
Thermador MB245
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0
Whirlpool MB7120XYB1
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ  Ref - Bottom Mounts
Maytag MBB1952GRW  Ref - Bottom Mounts
Maytag MBB1952HEB Ref - Bottom Mounts
Maytag MBB1952HEQ Ref - Bottom Mounts
Maytag MBB1952HEW Ref - Bottom Mounts
Maytag MBB1954GEB  Ref - Bottom Mounts
Maytag MBB1954GEQ  Ref - Bottom Mounts
Maytag MBB1954GES  Ref - Bottom Mounts
Maytag MBB1954GEW  Ref - Bottom Mounts
Maytag MBB1954HEW Ref - Bottom Mounts
Maytag MBB1956GEB  Ref - Bottom Mounts
Maytag MBB1956GEQ  Ref - Bottom Mounts
Maytag MBB1956GES  Ref - Bottom Mounts
Maytag MBB1956GEW  Refrigerator
Maytag MBB1956HEB Ref - Bottom Mounts
Maytag MBB1956HEQ Ref - Bottom Mounts
Maytag MBB1956HES Ref - Bottom Mounts
Maytag MBB1956HEW Ref - Bottom Mounts
Maytag MBB2254GEB  Ref - Bottom Mounts
Maytag MBB2254GEQ  Ref - Bottom Mounts
Maytag MBB2254GES  Ref - Bottom Mounts
Maytag MBB2254GEW  Ref - Bottom Mounts
Maytag MBB2256GEB  Ref - Bottom Mounts
Maytag MBB2256GEQ  Ref - Bottom Mounts
Maytag MBB2256GES  Ref - Bottom Mounts
Maytag MBB2256GEW  Ref - Bottom Mounts
Maytag MBF1956HEB Ref - Bottom Mounts
Maytag MBF1956HEQ Ref - Bottom Mounts
Maytag MBF1956HES Ref - Bottom Mounts
Maytag MBF1956HEW Ref - Bottom Mounts
Maytag MBF1956KEB Ref - Bottom Mounts
Maytag MBF1956KEQ Ref - Bottom Mounts
Maytag MBF1956KEW Ref - Bottom Mounts
Maytag MBF2254HEB Ref - Bottom Mounts
Maytag MBF2254HEB14 Refrigerator
Maytag MBF2254HEQ Ref - Bottom Mounts
Maytag MBF2254HEQ14 Refrigerator
Maytag MBF2254HES White Westinghouse/refrigerator
Maytag MBF2254HEW Ref - Bottom Mounts
Maytag MBF2254HEW14 Refrigerator
Maytag MBF2255KEB Ref - Bottom Mounts
Maytag MBF2255KEB11 Refrigerator
Maytag MBF2255KEQ Ref - Bottom Mounts
Maytag MBF2255KEQ11 Refrigerator
Maytag MBF2255KEW Ref - Bottom Mounts
Maytag MBF2255KEW11 Refrigerator
Maytag MBF2256HEB Ref - Bottom Mounts
Maytag MBF2256HEQ Ref - Bottom Mounts
Maytag MBF2256HES Ref - Bottom Mounts
Maytag MBF2256HEW Ref - Bottom Mounts
Maytag MBF2256KEB Ref - Bottom Mounts
Maytag MBF2256KEB11 Refrigerator
Maytag MBF2256KEQ Ref - Bottom Mounts
Maytag MBF2256KEQ11 Refrigerator
Maytag MBF2256KEW Ref - Bottom Mounts
Maytag MBF2256KEW11 Refrigerator
Maytag MBF2258HEB Ref - Bottom Mounts
Maytag MBF2258HEQ Ref - Bottom Mounts
  #2 (permalink)
Old 07-08-2012, 05:48 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Your problem is likely with either the water temp control switch or the temp control board. You can try changing out the control switch as it is not too expensive and you can return it if you buy from this site and it does not fix the problem.
Given that the machine came with the house and so you have no money in it my recommendation is either use it as is, or turn off the hot water valve so you have cold/cold or if it's not too much trouble turn off the hot water after it fills so you get a cold water rinse.
Yeah I know its not a fix, but the price ($0.00) is right.
__________________
  #3 (permalink)
Old 07-10-2012, 10:12 AM
Junior Member
Default
Thanks sidfink43.
What part would the temperature control switch be?
AP4026829 - $50
Then if that didn't fix it I should try replacing the temp control board? - AP4028021 - $105
So looking at the diagram, it appears this is a fairly simple to access fix. unscrew the control panel using the screws on the top rear and I get access to the back side of the control panel?
I appreciate the $0 workaround and believe me if it were just me I'd drop in some easy access quarter-turn shut off valves but since my better half is involved I'll opt to invest $100 to do it right.
Thanks again!
  #4 (permalink)
Old 07-10-2012, 11:27 AM
Senior Expert
APP Volunteer
Default
Yes that is the part, and the board is on the parts diagram you can get using your model number.
If either of those two don't fix things that other option, highly unlikely is the valve assembly itself.
__________________
  #5 (permalink)
Old 07-14-2012, 09:29 AM
Junior Member
Default
Okay, so AP4026829 (temp control switch) arrived today, I installed it and the problem hasn't gone away.
Guessing my next step is to replace the temp control board AP4028021? --- could a bad board cause the ATC light to NEVER go off? Or is there something just for the ATC that would cause this? Or is it one in the same?
  #6 (permalink)
Old 07-14-2012, 04:38 PM
Senior Expert
APP Volunteer
Default
Yes, the bad board would cause problems with the light. Try replacing it and again if you bought from this site you can return the parts if they are not needed.
I understand this sounds like a pretty crude process, but the methodology of replacing things to see if that fixes it is about all you can do when a circuit board is in machine.
Good luck, hope that works.
__________________
  #7 (permalink)
Old 07-19-2012, 11:52 AM
Junior Member
Default Not the temp switch or the temp board. Next...?
Okay, so I dug back into the control panel yesterday, and pulled out the old temp control board and replaced it with the one I had ordered AP4028021.
Same result. Not fixed. On COLD/COLD the ATC light is still on and mixed hot and cold comes out during the fill.
I also put the old (but working) switch back in while I was under the hood. A little worried I might damage the new board trying to remove it and replace with new so I think I will leave it since it could decide to go out any day anyway - not sure how much more prying those plastic pins that hold the board in place are going to take either.
So what's the next and hopefully final option? I'm guessing it has something to do with a malfunction in a mixing valve? What is involved to make this repair? Is it a couple of screws on a back access panel, or more involved? The control panel was pretty easy to access, I'm thinking the next set of suggestions won't be so easy.
Thanks for your expertise and continued patience.
  #8 (permalink)
Old 07-19-2012, 05:25 PM
Senior Expert
APP Volunteer
Default
Go ahead and replace the valve assembly, this part here
Part number: AP4010168
It does have a thermistor so that may be the problem.
You can get to it by taking off the front panel and then taking out screws to lift up the top panel.
It should not be a difficult repair.
__________________
  #9 (permalink)
Old 07-24-2012, 08:49 AM
Junior Member
Default
Okay, so the valve assembly suggested is scheduled to arrive today - Sure hope this is the fix I've been looking for.
I've done some searching as to how to access this area to replace it and I'm a bit confused. You say front panel, but what I've read says top panel first on this model. Something like, insert a putty knife to release some springs in the top front and lift up the top panel. Does that sound right for the Maytag Atlantis model MAV7650AWW? I'm assuming I should also go ahead and remove the control panel beforehand (unscrew back, tilt forward, lift up and unplug the wiring harness from the bottom half of the washer?) This seems like it would then allow the top to lift off completely to access the internals to swap out the valve right? Thanks for your expertise, I just want to make sure I have the right plan before I start taking things apart.
Thanks again for ALL of your help.
  #10 (permalink)
Old 07-24-2012, 10:37 AM
Senior Expert
APP Volunteer
Default
Some of these models open from the front, some front the top. If there are no screws in the front then the top should open up. You should be able to do the repair without removing the console, just leave it attached to the top.
Once you have the top open it should be obvious how to proceed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidarie Water leaking in ICW make while dispensing water from water dispenser psanand Refrigerator & Freezer Repair 0 05-12-2012 06:32 PM
Water refilling ice or water dispenser=water spraying in fridge cheshirekitti Refrigerator & Freezer Repair 2 01-30-2012 09:28 AM
Fridge water dispenser water trickles out hear tapping sound (but makes ice) Davidsgirl Refrigerator & Freezer Repair 5 03-28-2011 06:22 AM
Freezer stopped working, electrical arc or odor, & leaking water from water/ice line elmwood Refrigerator & Freezer Repair 1 10-10-2010 08:25 AM
Water Dispener on Whirlpool Fridge Makes Noise and Vibrates Water Line But No Water ugagrad04 Refrigerator & Freezer Repair 0 07-20-2010 06:43 PM
