imotay
#1 Posted : Friday, July 6, 2012 6:23:04 AM(UTC)
imotay
My washer has the ATC function. ATC has 3 settinsg (hot, warm, cold). The is also a cold setting for NON ATC setting. Currently the temperature is the same (hot) no matter what selection is made in ATC mode. When I turn to NON ATC mode (cold), the water is cold. I have replaced the ATC switch and that did not correct the issue. I have been told that it could be valve in the back and have been told that there is no way the valve is the issue sice the cold works when I turn it to cold (in non ATC mode). Not sure if I should replace the valve or if I am missing something else. Any suggestions will be appreciated...Thanks
Simon / APP Team
#2 Posted : Friday, July 6, 2012 10:05:27 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely there is a bad water mixing valve
Part number: 40107001
Here are the breakdown diagrams and Replacement parts for Maytag SAV515DEWW WASHER-TOP LOADING | AppliancePartsPros.com
Thank you. Post the results.
Simon.
PS. You can always return any unused parts even if they been installed.
imotay
#3 Posted : Tuesday, July 10, 2012 1:55:35 PM(UTC)
imotay
I replaced the mixing valve. So now the switch and valve have both been replaced and the issue has not been resolved. Any other suggestions?
Simon / APP Team
#4 Posted : Tuesday, July 10, 2012 3:18:57 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Sorry for the inconvenience, it's not always easy to diagnose the problem from the distance. After double checking I think it's the ATC board Part number: 27001208
You can return the other parts.
Thank you.
Simon.
imotay
#5 Posted : Thursday, July 12, 2012 4:48:57 PM(UTC)
imotay
I bought the temperature control board and installed it today. Problem has been corrected. ATC is now functioning as it should
Thanks for all of the help and suggestions
Simon / APP Team
#6 Posted : Thursday, July 12, 2012 4:56:35 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
