| » my washer timer is not pulling out or going in |
Model Number: wvsr1060g2ww Brand: GE Age: 5 - 10 years
my washer timer knob. right now is acting like you have the knob pulled out. you spin it and it turns that cycle on automatically. no need to pull on knob. I am thinking that the timer is failing. it still goes thru the cycles but now its doing. this. I am planning on just getting a new timer. I know that most people would just throw it away and get a new washer but i would rather fix it and extend the life of something.
Is there anything else that it could be? the knob also does not seem to grip when you go to select cycles. You have to grab hold of the ring that is right against the control panel and spin it to select your cycle. thank you for any and all help Ads By Google Related Models |
I think you are in luck. The plastic teeth on the timer knob on these GE models break a lot, and you may be able to fix things by just replacing the knob.
Here is the parts diagram for your model. Controls & backsplash replacement parts for General Electric WVSR1060G2WW Washer | AppliancePartsPros.com Notice the U shaped clip behind the timer knob. Use needle nose pliers to pull it off and the old knob will come off. Put on a new knob and you may be all set!
__________________
| Display Modes | |
| motor not pulling into place | mikies | Washer Repair | 1 | 08-02-2011 08:00 PM |
| Pulling out dryer motor | pstulken | Dryer Repair | 1 | 12-28-2010 07:27 PM |
| pulling error codes | pdq_wizzard | Washer Repair | 2 | 02-25-2010 08:09 PM |
| Door won't Close without pulling it up | mageegd | Refrigerator & Freezer Repair | 1 | 01-07-2009 08:01 AM |
