Discuss
Timer no good??
 in
Washer Repair
A bit of a saga... -Washer stopped mid load full of water. I suspected lid switch so applied a jumper
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Timer no good??
  #1 (permalink)
Old 07-05-2012, 06:17 AM
Junior Member
nukesul is on a distinguished road
Default Timer no good??
Model Number: KAWS700JQ4   Brand: Kitchen Aid   Age: 5 - 10 years
A bit of a saga...
-Washer stopped mid load full of water. I suspected lid switch so applied a jumper to bypass the switch. This worked to get the machine to drain but then timer ran continuously regardless of timer switch (in/out) position.
-Ordered a lid switch and machine drained some more and agitator started but no cycle can now be selected. Agitator goes but no other cycle can be entered regardless of timer position.
-According to the electrical diagram all switches should be open when timer switch is open however I now have 120v at the timer motor and level switch no matter the timer switch position.(in/out) The timer motor no longer seems to be driving.
I suspect I have a stuck contact(s) in the timer switch and have now burnt out the timer motor so it is stuck in one mode of operation. Does this sound right? Any other scenarios? Thanks
Ads By Google
Related Models
Whirlpool KAWS700JQ4
Whirlpool KAWS700JT0
Whirlpool KAWS700JT1
Whirlpool KAWS700JT2
Whirlpool KAWS700JT3
Whirlpool KAWS700JT4
Whirlpool KAWS700LQ0
Whirlpool KAWS700LT0
Whirlpool KAWS750GQ0
Whirlpool KAWS750GQ1
Whirlpool KAWS750GT1
Whirlpool KAWS750GZ0
Whirlpool KAWS750GZ1
Whirlpool KAWS750JQ0
Whirlpool KAWS750JQ1
Whirlpool KAWS750JQ2
Whirlpool KAWS750JQ3
Whirlpool KAWS750JQ4
Whirlpool KAWS750JT0
Whirlpool KAWS750JT1
Whirlpool KAWS750JT2
Whirlpool KAWS750JT3
Whirlpool KAWS750JT4
Whirlpool KAWS750LQ0 Automatic Washer
Whirlpool KAWS750LQ1 Automatic Washer
Whirlpool KAWS750LQ2 Automatic Washer
Whirlpool KAWS750LQ3 Automatic Washer
Whirlpool KAWS750LQ4 Automatic Washer
Whirlpool KAWS750LT0 Automatic Washer
Whirlpool KAWS750LT1 Automatic Washer
Whirlpool KAWS750LT2 Automatic Washer
Whirlpool KAWS750LT3 Automatic Washer
Whirlpool KAWS750LT4 Automatic Washer
Whirlpool KAWS777EQ0
Whirlpool KAWS777EZ0
Whirlpool KAWS800GQ0
Whirlpool KAWS800GQ1
Whirlpool KAWS800GZ0
Whirlpool KAWS800GZ1
Whirlpool KAWS850GQ0
Whirlpool KAWS850GQ1
Whirlpool KAWS850GT0
Whirlpool KAWS850GT1
Whirlpool KAWS850GZ0
Whirlpool KAWS850GZ1
Whirlpool KAWS850JQ0
Whirlpool KAWS850JQ1
Whirlpool KAWS850JQ2
Whirlpool KAWS850JQ3
Whirlpool KAWS850JQ4
Whirlpool KAWS850JT0
Whirlpool KAWS850JT1
Whirlpool KAWS850JT2
Whirlpool KAWS850JT3
Whirlpool KAWS850JT4
Whirlpool KAWS850LE0
Whirlpool KAWS850LE1 Automatic Washer
Whirlpool KAWS850LE2 Automatic Washer
Whirlpool KAWS850LQ0
Whirlpool KAWS850LQ1 Automatic Washer
Whirlpool KAWS850LQ2 Automatic Washer
Whirlpool KAWS850LT0
Whirlpool KAWS850LT1 Automatic Washer
Whirlpool KAWS850LT2 Automatic Washer
Whirlpool KAWS855JE0
Whirlpool KAWS855JE1
Whirlpool KAWS855JE2
Whirlpool KAWS855JE3
Whirlpool KAWS855JE4
Whirlpool KAWS977EQ0
Whirlpool KAWS977EZ0
Bosch KB030-062
Bosch KB032-062
Bosch KB035-062
Bosch KB036-062
Bosch KB090-054
Bosch KB091-054
Bosch KB100-046
Frigidaire KB122G0 Wwh(v1) / Built - in Oven
Frigidaire KB122G1 Wwh(v2) / Built - in Oven
Frigidaire KB122G2 Wwh(v3) / Built - in Oven
Frigidaire KB122G3 Wwh(v4) / Built - in Oven
Frigidaire KB122G4 Wwh(v5) / Built - in Oven
Frigidaire KB122LM0 Wwh(v1) / Wall Oven
Frigidaire KB122LM1 Wwh(v2) / Wall Oven
Frigidaire KB122LM2 Wwh(v1) / Wall Oven
Frigidaire KB122LMO Wwh(v1) / Wall Oven
Frigidaire KB152LM0 Wwh(v1) / Electric Range
Frigidaire KB152LM1 Wwh(v1) / Electric Range
Frigidaire KB152LM2 Wwh(v1) / Electric Range
Whirlpool KB26G1X-3 6 Qt. Stand Mixer
Whirlpool KB26G1XAC3 6 Qt. Stand Mixer
Whirlpool KB26G1XAC5 6 Qt. Stand Mixer
Whirlpool KB26G1XBU3 6 Qt. Stand Mixer
Whirlpool KB26G1XBU5 6 Qt. Stand Mixer
Whirlpool KB26G1XER3 6 Qt. Stand Mixer
Whirlpool KB26G1XER5 6 Qt. Stand Mixer
Whirlpool KB26G1XGN3 6 Qt. Stand Mixer
Whirlpool KB26G1XGR3 6 Qt. Stand Mixer
Whirlpool KB26G1XGR5 6 Qt. Stand Mixer
Whirlpool KB26G1XMC3 6 Qt. Stand Mixer
Whirlpool KB26G1XMC5 6 Qt. Stand Mixer
Whirlpool KB26G1XMY3 6 Qt. Stand Mixer
Whirlpool KB26G1XMY5 6 Qt. Stand Mixer
Whirlpool KB26G1XOB3 6 Qt. Stand Mixer
Whirlpool KB26G1XOB5 6 Qt. Stand Mixer
Whirlpool KB26G1XPT3 6 Qt. Stand Mixer
Whirlpool KB26G1XPT5 6 Qt. Stand Mixer
Whirlpool KB26G1XTG3 6 Qt. Stand Mixer
Whirlpool KB26G1XTG5 6 Qt. Stand Mixer
Whirlpool KB26G1XWW3 6 Qt. Stand Mixer
Whirlpool KB26G1XWW5 6 Qt. Stand Mixer
Whirlpool KB3SS
Frigidaire KB443GDM0 Wwh(v1) / Electric Continuous Clean Oven
Frigidaire KB443GDM1 Wwh(v2) / Electric Continuous Clean Oven
Frigidaire KB443GDM2 Wwh(v1) / Electric Range
Frigidaire KB443LM1 Wwh(v1) / Electric Range
Frigidaire KB563LM0 Wwh(v1) / Wall Oven
Frigidaire KB663GDM0 Wwh(v1) / Electric Self - Clean Oven
Frigidaire KB663GDM1 Wwh(v2) / Electric Self - Clean Oven
  #2 (permalink)
Old 07-06-2012, 05:57 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
It sounds very much like your timer is out of whack. Go ahead and replace it and that should fix your problem. If you order from this site and the part does not fix the problem you can return it, see the returns policy for details.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Good as new! oldmill Dishwasher Repair 0 08-01-2011 07:04 AM
Whirlpool Dryer timer test good but not working ctbasscatcher Dryer Repair 1 09-08-2010 01:19 PM
Maytag washer, timer good till rinse-no spin,drain orstop/timer keeps clicking freely partsparts Washer Repair 3 08-23-2010 01:50 AM
Good Morning! David Norwood Dryer Repair 2 11-16-2009 06:45 PM
