| » No Spin after draining in Slow, Gentle Cycles |
Model Number: 110.2205 Brand: Kenmore Age: 5 - 10 years
When running Permanent Press or Handwash/Casual cycles (slow ones) the cycle proceeds until after draining. When the Spin tries to start, it seems like the motor engages for a second, and then drops out. This repeats about every two or three seconds until the machine is shut off. It is a fairly violent action.
In Heavy or Normal Cycles everything runs fine. There is no gearbox noise. Everything is smooth and quiet. Even in the troubled cycles all goes well until attempted spinning after draining. When running Diagnostic Test called RECIRCULATION PRESSURE SWITCH TEST this same repetetive starting/stopping occurs. Display shows Er immediately until I stop the test. Motor resistances are ok. Both pressure switches ok. Motor Coupler still good. I can turn the input to the transmission by hand and all seems ok. It almost seems like the logic in the controller has changed, but I don't see how that could be. Is there ever a need to reload a logic program into the control? Ads By Google Related Models |
This does sound like a control unit problem, since the machine performs well in some cycles. Replacing the control unit is your first step.
If you need more info please post a full model number so we can see exactly what model you have.
__________________
Quote:
Quote:
This solved the problem. Machine now works perfect in all cycles. |
| Display Modes | |
| washer won't drain or spin in gentle mode | Frub | Washer Repair | 6 | 05-13-2011 10:00 AM |
| washer agitates fast and slow then shuts off on gentle settings only | 4robnzak | Washer Repair | 0 | 04-27-2011 02:13 PM |
| Whirlpool won't spin on gentle knit cycle | Bowdaddy | Washer Repair | 2 | 04-17-2011 09:38 AM |
| Spin works only in Gentle Mode | riccastles | Washer Repair | 2 | 08-21-2009 03:16 PM |
| Gentle cycle/slow spin speed problem | WFH | Washer Repair | 1 | 01-19-2008 08:17 PM |
