Discuss
how do you check for a bad lid switch ?
 in
Washer Repair
How do you check for a bad lid switch if tub is not draining and all tubes are clear; pump
Appliance Repair Forum > Appliance Repair Help > Washer Repair » how do you check for a bad lid switch ?
  #1 (permalink)
Old 07-02-2012, 03:50 PM
Junior Member
louisa is on a distinguished road
Default how do you check for a bad lid switch ?
Brand: GE   Age: 5 - 10 years
How do you check for a bad lid switch if tub is not draining and all tubes are clear; pump is clean too.
Ads By Google
  #2 (permalink)
Old 07-04-2012, 06:14 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
You can use a multi-meter to test continuity when the switch is closed. Also, you can use a jumper wire or wire with clips to by pass it. If the machine works then replace the switch.
If you need more info please post a full model number so we can see what you have.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Igniter-check, Flame sensor-check now what? Ron Wan Dryer Repair 0 11-01-2011 06:37 PM
washer won't agitate unless "jump wire" lid check switch wings Washer Repair 1 08-13-2010 01:46 PM
"check" switch? kjc Washer Repair 2 01-10-2010 09:26 PM
how to check switch jam11683 Oven Repair (including Ranges and Cooktops) 1 06-26-2009 11:15 PM
How to remove door cover to check switch AZEERAK Dishwasher Repair 1 08-30-2008 01:26 PM
