| » washer stopped agitating and spinning |
Model Number: WJRR4170G1WW Brand: GE Age: 5 - 10 years
The washer stopped agitating & spinning today - fills and drains fine, cycles ok too no loud noises of any kind, nothing amiss leading up to this- I'd appreciate any help in figuring out a repair. Simple I hope. Researching parts it looks like it could be the lid switch - is that a fairly common failureand is there any temporary fix till part comes? UPDATE: WE CHECKED THE LID SWITCH WITH OHM METER AND ITS WORKING _ ANY OTHER IDEAS ON WHAT COULD CAUSE THIS _ IS THERE ANOTHER SWITCH OR RELAY??
Ads By Google Related Models Last edited by splash13 : 07-01-2012 at 09:31 AM. Reason: UPDATED |
This machine has a mode shifter and the motor has a built in diagnostic device which flashes lights to signal an error code.
Here is a site that will tell you how to intepret the codes. HydroWave GE Washer Repair Guide First try resetting it, sometimes that is all that is needed. If that does not work and you cannot get a good error code reading the problem is likely the motor. Operate the machine with the front panel off and see if the motor is turning during agitation or spin functions.
__________________
Sorry it took so long to post this but your information was perfect and my husband was able to repair it the next day. It only ended up being a reset issue so we were greatly relieved and saved much money due to your insight. We have received other valuable info from this site and buy any necessary parts here when needed. I appreciate the wealth of knowledge offered along with the necessary parts and will always come here first.
| Display Modes | |
| Washer Just Stopped Agitating, Draining, and Spinning. | icepique | Washer Repair | 3 | 04-23-2012 05:18 PM |
| Washer not spinning or agitating | drslgsr | Washer Repair | 1 | 05-30-2011 05:03 PM |
| Washer not spinning or agitating | jramirez1021 | Washer Repair | 1 | 01-31-2011 09:23 AM |
| Washer - not agitating or spinning | char2234 | Washer Repair | 0 | 06-30-2010 12:16 PM |
| washer not spinning or agitating again. | bounette77 | Washer Repair | 2 | 02-17-2010 11:00 AM |
