Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   whirpool washer fills but wont shut off (http://forum.appliancepartspros.com/washer-repair/485220-whirpool-washer-fills-but-wont-shut-off.html)
pete1949 06-29-2012 12:57 PM
Washer fills but wont shut off on any setting of water level switch. I have replaced water level switch and have the same results.
Help !!!
Simon / APP Team 06-29-2012 06:44 PM
Hi.
When you unplug the washer does the water stops?
If not - replace the water inlet valve.
If it stops - check the air pressure hose and air dome for cracks, holes or obstructions.Check if it's still connected at the bottom and top.
Post the results.
Simon.
pete1949 06-30-2012 05:47 AM
Thanks! I'll check those and see what i can find out...
pete1949 07-02-2012 11:59 AM
Thanks Simon. Checked the water fill hose and sure enough it had worn at the plastic clamp on the side of the tub until it produced a whole. Went to Lowes and bought new hose with the same ID, installed and was back in business. Thanks Again....
Simon / APP Team 07-02-2012 12:08 PM
You are welcome.
Simon.
