| » Washer Makes Noise/Tub Seems Loose |
Model Number: YBXR1060T5WW RCA Brand: -brand- Age: More than 10 years
My RCA washer which is 11 years old, but only used at a summer home, makes noise. The entire tub inside seems loose and wobbles back and forth when I touch it. It almost looks like the tub inside is so loose it is not attached to something. Can anyone please help me. I can't find my manual. Do I take the front off of it and check something out inside. Pls. help. Nancy
Related Models |
There are two common things that will cause these washers to become noisy.
The suspension rods will squeak. This would be noisy during wash. The tub seal will leak (one or two drops a load) causing the transmission to be noisy during spin. The tub may have come loose from the transmission but it is normal for it to be somewhat loose. You can remove agitator (just pull up) then remove the 7/16 screw to remove the agitator coupling. Once done you can see if the big nut that holds the tub in is loose. This link will help GE Washer Disassembly Guide |
| Display Modes | |
| Excessive washer noise, loose Agitator | PeteSchwiede | Washer Repair | 1 | 09-25-2009 06:31 PM |
| Washer makes grinding noise. | Joseph01 | Washer Repair | 1 | 09-02-2009 05:50 AM |
| Washer makes noise and won't agitate | sdgrown | Washer Repair | 1 | 05-27-2009 05:09 PM |
| washer won't spin, makes noise | brokenshoe | Washer Repair | 3 | 07-01-2008 08:05 PM |
| Washer makes noise and does not spin | rjr | Washer Repair | 1 | 12-30-2007 02:08 AM |
