| » maytag washer does not spin fast after rinse cycle |
Model Number: mav5000aww Brand: Maytag Age: More than 10 years
machine seems to wash, inner tub spin slow and agitator moves but during the rinse cycle, machine suppose to spin fast to ring out clothes but only see the agitator moving. water drains but leaves clothes wetter than normal. can you please help me determine what's causing it so i can purchase the correct part. thank you very much.
Hi.
Does the washer agitates on spin ? Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
The inner tub suppose to spin (move) only during the Spin cycle. So, does the washer spin at all when you turn the timer to Spin? Simon.
__________________
Open the front panel using the putty knife (two clips at the top) and check if the motor reversing when you change cycle from wash to spin.
Simon.
__________________
Simon,
Finally got a chance to look at the machine. In the SPIN cycle, I could not tell if the motor reversed but I could see the TUB rotate clockwise but spins like something is holding it back to do a fast spin. I've repeated this several times and couple of times the TUB didn't even spin at all, although the agitator spun. |
Hi.
There is an even chance that it's a bad thrust bearing or the transmission. The bearing job is much less $$ and easier too. Here are the breakdown diagrams and Replacement parts for Maytag MAV5000AWW WASHER, ATLANTIS | AppliancePartsPros.com Thank you. Simon.
__________________
| Display Modes | |
| MAytag washer wont spin fast enough | teammckenna | Washer Repair | 1 | 05-31-2012 06:12 PM |
| washer vibrates during fast spin cycle | pclaypool09 | Washer Repair | 2 | 10-14-2011 07:24 AM |
| Maytag washer will not spin after the rinse cycle | kempf25 | Washer Repair | 1 | 04-01-2011 07:19 PM |
| Roper washer spins on rinse cycle but not on spin cycle | Swica | Washer Repair | 4 | 03-07-2011 05:23 PM |
| Washer goes to rinse cycle then spin back to rinse, stuck in this mod | Pat66 | Washer Repair | 1 | 05-08-2009 07:44 AM |
