Discuss
Kenmore washer agitates but does not spin or drain
 in
Washer Repair
The washer agitates but does not spin or drain. If I move the dial to rinse it just agitates. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer agitates but does not spin or drain
  #1 (permalink)
Old 06-28-2012, 12:52 PM
Junior Member
j-a-z is on a distinguished road
Default Kenmore washer agitates but does not spin or drain
Model Number: 110.92293810   Brand: Kenmore   Age: More than 10 years
The washer agitates but does not spin or drain. If I move the dial to rinse it just agitates. I have checked the lid switch and if I manually close the switch (with the lid open) and turn the dial to spin it just agitates faster but does not drain, it never spins.
Ads By Google
Related Models
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
  #2 (permalink)
Old 06-28-2012, 04:31 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Dew to the age of the washer I'm not able to locate any technical info and diagram.
From the data your provided most likely the problem is a bad timer. It shows as no longer available. You may try the internet search. The part #3358112.
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-28-2012, 04:52 PM
Junior Member
Default
Hi Simon,
Why do you suspect the timer? If I manually put it to spin and it does not spin wouldn't that be some other switch or gear or???. I have two places on the dial that say spin, one after the rinse and one that says"spin only". If I turn it on either one it only agitates very strongly but the tub does not move.
  #4 (permalink)
Old 06-28-2012, 05:31 PM
Expert
Default
If you turn the timer to SPIN the motor reversing and washer starts draining.(assuming the lid switch is OK).
When the tub is empty, the timer pausing witch allow the spin gear inside the transmission to engage.
Washer agitates only and not draining - the timer not reversing the motor.This is my honest opinion.
Simon.
__________________
  #5 (permalink)
Old 06-28-2012, 06:17 PM
Junior Member
Default
OK..I did not understand all the things a timer does. I will try to locate one. Thanks
  #6 (permalink)
Old 07-16-2012, 02:04 PM
Junior Member
Default
Ho Simon... I hope you are around. I was able to locate the timer at Sears parts and it came today. It is an exact match and I installed it easily... BUT...the washer still does not spin or drain. If I set it to spin the agitator just moves up and down real fast.
  #7 (permalink)
Old 07-30-2012, 05:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Just to add my 2 cents...
Quote:
Originally Posted by j-a-z View Post
...I have checked the lid switch and if I manually close the switch (with the lid open)...
Can you explain it more detailed please?
There are two ways how to test the lid switch. One is to check it for continuity and the other one is to bypass it. Only such tests are reliable enough to say that the switch is good.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer agitates but won't drain or spin Crabby1 Washer Repair 1 04-26-2010 08:09 AM
washer agitates won't drain or spin b2thej1 Washer Repair 1 08-05-2009 07:46 PM
washer agitates ONLY won't drain or spin MikMac Washer Repair 2 05-18-2009 02:29 AM
Washer sort of agitates, but doesn't drain/spin eawalter Washer Repair 1 01-02-2009 05:18 AM
Washer barely agitates, won't drain or spin jsc2010 Washer Repair 4 09-12-2007 02:55 AM
