After 12 years with no issues, my Bosch washing machine now won't run any cycle that uses warm/hot water. When I try it makes a humming noise and gets no water. If I move the dial to something that requires just cold water it works fine.
I have checked that my Hot supply has pressure. I have also checked for a fault code, but get 00. Any Suggestions?
Thanks,
-Bruce
