| » Washer will not drain |
Model Number: WPSR3120W2WW Brand: GE Age: 5 - 10 years
my ge washer just stopped draining. I have changed the pump and still wont work. I checked the lid switch and it is ok. I guess the next thing is the timer(plastic case) but I dont know how to check it to see if it is bad. I dont want to spend more money on it if it is not the timer. any sugestions?
Hi.
Have you checked the pump inlet and drain hoses for possible restrictions? Is there a 120vac to the drain pump when timer is set to drain and spin? Please post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Simon yes I've checked both the inlet and drain hoses for obstructions, they were clear. as for the 120vac? how do you check,I have a multi meter but very knowledable at using it. I also found a ground wire broke that attached to the moter bracket fixed it but still not working.
OK i've checked the vac at the pump and it reads 55.8. does that mean that the timer is bad?
Hi.
If you are sure that the lid switch is OK than most likely it's the timer. The timer Part number: WH12X10077 Here are the breakdown diagrams and Replacement parts for General Electric WPSR3120W2WW Washer | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
| Display Modes | |
| Washer will only drain if put on "Drain+Spin" cycle. | Arieleno | Washer Repair | 7 | 11-02-2011 07:03 PM |
| My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
| Washer does not drain | svanneste | Washer Repair | 1 | 03-12-2010 04:02 AM |
| Washer won't drain | nsimone1056 | Washer Repair | 7 | 05-22-2008 05:18 PM |
| Calypso Washer Washer Won't Drain | SamB | Washer Repair | 3 | 11-27-2007 01:41 PM |
