i have a bosch wfmc3200uc front load washer that does not spin. When the spin cycle is selected the timer reads 9 mins and runs down to 8 mins at this time the pump is running, but then the timer jumps to 2mins and never spins. The belt is good and is not slipping, the motor never seems to run, but it seems like it is getting no signal to run. HELP!
I wish we could hellp but I don't think those of us who reply on this Forum have experience with Bosch.
I suggest you try another Forum.
Good luck, sorry we could not be of more help.
Originally Posted by: jimconnolly i have a bosch wfmc3200uc front load washer that does not spin. When the spin cycle is selected the timer reads 9 mins and runs down to 8 mins at this time the pump is running, but then the timer jumps to 2mins and never spins. The belt is good and is not slipping, the motor never seems to run, but it seems like it is getting no signal to run. HELP! Does it behave the same way in all cycles?
Originally Posted by: sidfink43 I wish we could hellp but I don't think those of us who reply on this Forum have experience with Bosch. I suggest you try another Forum. Good luck, sorry we could not be of more help. speak for yourself
