Discuss
Maytag Neptune stops multiple times throughout wash cycle
 in
Washer Repair
In the previous thread I started, I was convinced I had this issue figured out so I was moving on
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Neptune stops multiple times throughout wash cycle
  #1 (permalink)
Old 06-26-2012, 08:27 PM
Junior Member
dpilot83 is on a distinguished road
Default Maytag Neptune stops multiple times throughout wash cycle
Model Number: MHS2000AWW   Brand: Maytag   Age: More than 10 years
In the previous thread I started, I was convinced I had this issue figured out so I was moving on to the smaller issues. Now it's apparent that I don't have it figured out.
It's a Maytag Neptune Model MHS2000AWW. First of all, I'll describe the location in case that has any implications. It's in the basement so it has to pump it's waste water uphill.
It's been having problems for a long time now. Occasionally (sometimes more frequently than others) it will have sopping wet cloths when it completes the wash cycle. You have to run in through the last portion of the wash cycle again, and sometimes multiple times to get it to clean the water out of the tub so that you can move the cloths to the dryer.
Recently it has initiated a pattern where it stops occasionally mid cycle. I pulled the supply hoses off and replaced the screens (which were very clogged) but it still stops. The stopping has become more frequent, to the point where it's nearly unbearable trying to get any clothes washed. The last couple of cycles we tried before we started working on it, it would stop very frequently.
As a diagnostics step, we pulled the waste hose off of the drain pipe that goes to the sewer system and we let it run in to 5 gallon buckets. We were able to go through 2 complete wash cycles and the washer did not stop mid cycle a single time. We decided that it must be that there is a plug in the pipes that lead to our sewer system that prevents flow out the waste pipe. We ran a snake down the pipes and didn't come up against any convincing obstructions so we attached a garden hose to the pipe and ran water through the pipes that way and water freely ran to the sewer system through the drain pipe for the washer. We thought maybe we had broken something loose so we tried again. The washer stopped the first time it had to drain the tub in the cycle. I put the hose in the 5 gallon bucket again and turned the washer on and then tried to restrict the flow of water into the waste bucket. The waste pump on the washer was generating plenty of pressure. If I had wanted to I could have sprayed all over the place like you would if you were trying to wash your car without a nozzle on the end of your garden hose.
So in my mind, the waste pump is still good, the drain is clean, but somehow the difference between pumping uphill and pumping into a 5 gallon bucket is still causing problems. Does anyone have any ideas? Thanks.
Ads By Google
Related Models
Maytag MHW2000AWW Stacked Washer
Whirlpool MHWZ400TB00 Automatic Washer
Maytag MHWZ400TB00 Automatic Washer
Whirlpool MHWZ400TQ00 Automatic Washer
Maytag MHWZ400TQ00 Automatic Washer
Whirlpool MHWZ600TB00 Automatic Washer
Maytag MHWZ600TB00 Automatic Washer
Whirlpool MHWZ600TK00 Automatic Washer
Maytag MHWZ600TK00 Automatic Washer
Whirlpool MHWZ600TW00 Automatic Washer
Maytag MHWZ600TW00 Automatic Washer
General Electric MIG23MIMHFBB Refrigerator
General Electric MIG23MISAFBB Refrigerator
General Electric MIG23MISBFBB Refrigerator
Maytag MIP85S Misc / Accessory
Maytag MIP85T-2 Misc / Accessory
General Electric MK KIT 1
Whirlpool MK100
Whirlpool MK110
Jenn-Air MK241B Misc / Accessory
Jenn-Air MK241W Misc / Accessory
Jenn-Air MK24B Misc / Accessory
Jenn-Air MK24W Misc / Accessory
Jenn-Air MK271B Misc / Accessory
Jenn-Air MK271W Misc / Accessory
Jenn-Air MK272B Misc / Accessory
Jenn-Air MK272W Misc / Accessory
Jenn-Air MK27B Misc / Accessory
Jenn-Air MK27W Misc / Accessory
Jenn-Air MK301B Misc / Accessory
Jenn-Air MK301W Misc / Accessory
Jenn-Air MK302B Misc / Accessory
Jenn-Air MK302W Misc / Accessory
Jenn-Air MK30B Misc / Accessory
Jenn-Air MK30W Misc / Accessory
Amana ML-1 Mwave - Family Size (60 Hz)
Amana ML-10 Mwave - Family Size (60 Hz)
Amana ML-2 Mwave - Family Size (60 Hz)
Amana ML-3 Mwave - Family Size (60 Hz)
Whirlpool ML02CCXHW
Whirlpool ML02CCXHW1
Whirlpool ML03CCXHW
Whirlpool ML03CCXHW1
Whirlpool ML05CCXHW
Whirlpool ML05CCXHW1
Amana ML10 Mwave - Cntrtp / Stand Alone
Amana ML40 Mwave - Cntrtp / Stand Alone
Amana ML441T Mwave - Cntrtp / Stand Alone
Amana ML446P Mwave - Cntrtp / Stand Alone
Amana ML451T Mwave - Cntrtp / Stand Alone
Frigidaire MLCE52RCS0 Tap(v1) / Laundry Center
Frigidaire MLCE52RCS1 Frg(v1) / Laundry Center
Frigidaire MLCE52RCT0 Tap(v2) / Laundry Center
Frigidaire MLCE52RCT1 Frg(v2) / Laundry Center
Amana MLD510  Commercial Microwaves
Amana MLD510D  Commercial Microwaves
Maytag MLE15MNAGW Dryer - Ele
Maytag MLE15MNAYW Stacked Dryer - Electric
Maytag MLE15MNAZW Stacked Dryer - Electric
Maytag MLE15PDAGW Dryer - Ele
Maytag MLE15PDAUW Dryer - Ele
Maytag MLE15PDAYA Dryer - Ele
Maytag MLE15PDAYQ Dryer - Ele
Maytag MLE15PDAYW Dryer - Ele
Maytag MLE15PDAZW Stacked Dryer - Electric
Maytag MLE15PDBGW Dryer - Ele
Maytag MLE15PDCZW Stacked Dryer - Electric
Maytag MLE15PRAYW Stacked Dryer - Electric
Maytag MLE15PRAZW Stacked Dryer - Electric
Maytag MLE19PDAGW Dryer - Ele
Maytag MLE19PDAYW Stacked Laundry - Ele
Maytag MLE19PDAZW Stacked Laundry - Ele
Maytag MLE19PDCZQ Dryer - Ele
Maytag MLE19PDCZW Dryer - Ele
Maytag MLE19PDDGW Stacked Laundry - Ele
Maytag MLE19PDDYW Stacked Laundry - Ele
Maytag MLE19PNAUW Dryer - Ele
Maytag MLE19PNAYW Dryer - Ele
Maytag MLE19PNDYW Stacked Laundry - Ele
Maytag MLE19PRAYW Dryer - Ele
Maytag MLE19PRAZW Dryer - Ele
Maytag MLE19PRDYW Stacked Laundry - Ele
Maytag MLE2000AYW Stacked Laundry - Ele
Maytag MLE2000AZW Stacked Laundry - Ele
Maytag MLE23MNAUW Dryer - Ele
Maytag MLE23MNAYW Stacked Dryer - Electric
Maytag MLE23MNFYW Stacked Dryer - Electric
International MLE23PDAGW Dryer - Ele
Maytag MLE23PDAUW Dryer - Ele
Maytag MLE23PDAYQ Stacked Dryer - Electric
Maytag MLE23PDAYW Stacked Dryer - Electric
Maytag MLE23PDFGW Stacked Dryer - Electric
Maytag MLE23PDFUW Stacked Dryer - Electric
Maytag MLE23PDFYW Stacked Dryer - Electric
Maytag MLE23PDFZW Stacked Dryer - Electric
Maytag MLE23PDHGW Stacked Dryer - Electric
Maytag MLE23PDHYW Stacked Dryer - Electric
Maytag MLE23PDHZW Stacked Dryer - Electric
Maytag MLE23PRAYW Stacked Dryer - Electric
Maytag MLE23PRFYW Stacked Dryer - Electric
Maytag MLE23PRFZW Stacked Dryer - Electric
Frigidaire MLF303PGDA Frg(v1) / Gas Range
Frigidaire MLF303PGDC Frg(v1) / Gas Range
Frigidaire MLF303PGDD Frg(v2) / Gas Range
Frigidaire MLF303PGWA Frg(v2) / Gas Range
Frigidaire MLF303PGWC Frg(v3) / Gas Range
Frigidaire MLF303PGWD Frg(v4) / Gas Range
Frigidaire MLF311SGDA Frg(v1) / Gas Range
Frigidaire MLF311SGDC Frg(v1) / Gas Range
Frigidaire MLF311SGDD Frg(v1) / Gas Range
Frigidaire MLF311SGWA Frg(v2) / Gas Range
Frigidaire MLF311SGWC Frg(v2) / Gas Range
Frigidaire MLF311SGWD Frg(v2) / Gas Range
International MLG15MNAEW Dryer - Gas
Maytag MLG15MNAGW Dryer - Gas
Maytag MLG15MNAWW Stacked Dryer - Gas
International MLG15PDAEW Dryer - Gas
  #2 (permalink)
Old 06-27-2012, 06:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The model number you posted does not come up anywhere. That means we are not able to find any technical information for this model. Unfortunately, without diagrams, schematics, parts list and/or manual we are not able to provide any accurate advice for you.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 09-24-2012, 06:47 PM
Junior Member
Default Model number
I find it odd that it's not possible to find model information. If I search google for that model number I find multiple threads about incomplete draining. Do they eventually get rid of old parts and service manuals?
I have solved the stopping frequently by finally getting a sump pump installed in the basement so the washer does not have to do the heavy lifting. Still doesn't always drain completely though. Haven't been able to catch it in the act yet, but I suspect it's not actually spinning in the spin cycle.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune TL Stops in Wash mbacko1 Washer Repair 6 06-03-2012 10:31 AM
maytag neptune stops after wash cycle willy t Washer Repair 1 05-22-2012 05:49 PM
Washer works properly at times and stops between wash and spin/pump cycles at times sawgrassusa Washer Repair 0 02-26-2011 08:02 AM
Maytag SE 1000 washer stops mid cycle or won't start wash cycle katyat Washer Repair 1 09-11-2009 04:15 PM
Must cycle multiple times to get clothes dry Windemere166 Dryer Repair 2 02-22-2009 07:02 AM
