| » Wash Load Very Wet |
Model Number: LS09549LWO Brand: Whirlpool Age: 5 - 10 years
On several occasions wash has come out very wet. It happens on small loads as well as large. This doesn't occur every time but enough to know that there is a mechanical problem occurring. Any suggestions on what to look for or repair? It to me seems the spin cycle is the problem. Could the pump have something backing up the draining of the washing load. Another question is there a lint screen or some means to collect or filter lint? One thing I would like two add is that I had a burning odor ( electric motor overheating smell) on about 3 occasions almost like a burning -belt. I believe this is a direct drive motor /no-belt. Any suggestions or ideas to a solution to my problem would greatly be appreciated. Thanks for the support you offer on this site. I recently repaired my whirlpool gas oven range with A.P.P. parts and expert technical advice from this site. Top notch I highly recommend the forum to all people.
Hi Todd,
The model number you posted does not come up. Verify and repost it please. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hi Todd,
This model number looks much better Remove the washer cabinet. Remove the drain pump and disconnect the hoses from the pump. Check for a foreign objects in side. Check for a foreign objects between the inner and the outer tubs. The outer tub is made of plastic and a good flashlight will help. The following video instructions will help you to disassemble it. - The drain pump Part number: 3363394 Here are the breakdown diagrams and Replacement parts for Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| Frig f/load does not wash or spin | Jim1657 | Washer Repair | 3 | 03-19-2012 03:04 PM |
| Can't wash a load!! | TOtoe | Washer Repair | 0 | 06-18-2010 03:37 AM |
| Ge Front Load Washer Won't Wash | HMACV1 | Washer Repair | 1 | 04-28-2010 08:11 AM |
| Wash load and tub spin CW during agitation | RedHog42 | Washer Repair | 6 | 10-01-2009 12:55 PM |
| Takes half a day for one load to wash | nurseongo | Washer Repair | 4 | 12-03-2008 08:51 AM |
