when it goes into final spin the water is drained and the motot is running but the final spin does not move I have the motor out and the coulpler is still good
Groups: APP Team
Hi. When the washer is in the spin open and in 5 sec.close the lid. If it spins - replace the timer. If not - the clutch. The clutch Part number: 285785
what is the sequence of operation of a wtw5500sto wash machine. time between operations
Groups: APP Team
Hi.
Your washer has a "neutral drain" transmission. This means that the washer first draining the water and then timer is pausing for a few seconds to engage the spin gear inside the transmission. When the timer turn on the motor after the pause the basket start spinning.
Simon.
