| » Washer puts water in drum does not turn only hums and water does not drain |
Model Number: wm2277hw Brand: -other- Age: 5 - 10 years
My LG WM2277HW will start to fill with water but the drum will not rotate, only hums, and in about 4-5 minutes the LE code comes up. The washer does not drain the water, only does the LE code. The washer is 8 years old. Replaced the Drive Motor Stator Assembly part AP4438648 and the Rotor Assembly part AP4438635. However, still have the same problem. Do I need to replace the Wiring Harness part AP4439126 or is it some other problem? I looked at the wiring harness and no outward sign of problem (no frayed wires or obvious damage).
| Display Modes | |
| Maytag washer, water remaining in drum? | toph236 | Washer Repair | 1 | 10-31-2011 05:24 PM |
| washer fills with water, but wont aggitate. it hums for about 5 seconds & shuts off | liquidarrows | Washer Repair | 1 | 07-29-2011 06:47 PM |
| washer hums when in normal wash and won't turn on | rmlmmccarty2012 | Dishwasher Repair | 0 | 03-14-2011 04:55 PM |
| Washer fills with water and hums | kanoonii | Washer Repair | 0 | 05-16-2010 03:00 PM |
| motor hums but drum will not turn | judy71635@alltel.net | Dryer Repair | 1 | 07-30-2008 08:28 PM |
