Discuss
Washer fills, won't agitate spin or empty
 in
Washer Repair
My Maytag Model A 612 will not drain, spin or agitate. Water will fill the tub if I empty the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer fills, won't agitate spin or empty
  #1 (permalink)
Old 06-22-2012, 06:23 PM
Junior Member
David L Spargo is on a distinguished road
Default Washer fills, won't agitate spin or empty
Brand: Maytag   Age: More than 10 years
My Maytag Model A 612 will not drain, spin or agitate. Water will fill the tub if I empty the tub of water below the setting on the console. The lid switch is good. The timer does not stop at stop. Instead it continues around the dial. There are no stuck or spinning motors sounds and the belts seem intact. In fact the unit is quiet. The thread posted by Charus Campbell sounds like exactly the same problem. About 6 months ago I replaced the water inlet valve when the water kept running. The new valve operates with a loud thunk--shutting the water on and off fast. It is much noisier than the old water inlet valve.
What should I do next?
  #2 (permalink)
Old 06-24-2012, 06:43 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Take off the front cover and observe the machine when it is trying to agitate or spin. If the motor is not turning then the problem can be the motor or the timer. You will need to test to see if power is getting to the motor. If so the motor is likely the issue, if not, the timer is suspect.
If the motor is trying to turn but cannot then something may be hung up in the transmission.
It may be time to consider replacing the machine. In our area you can replace that washer with a good basic top loader for about $325.00.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer fills, agitates does not empty or spin Jim Huwaldt Washer Repair 1 01-11-2012 09:33 AM
Washer fills but won't agitate or spin garystarh Washer Repair 1 09-30-2011 06:42 PM
kenmore 80 fills, wont spin, agitate or empty 6446bmw Washer Repair 3 09-16-2011 04:02 PM
washer fills,agitates,stops,won't empty or spin Modernman Washer Repair 2 08-22-2011 05:59 AM
Washer won't agitate,spin,or empty ian526788 Washer Repair 2 06-19-2011 03:43 AM
