Discuss
Maytag washer leaking oil
 in
Washer Repair
Hello everyone, I have a maytag washer that is leaking oil out the bottom transmission seal. The plastic dust cover
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer leaking oil
  #1 (permalink)
Old 01-25-2008, 06:03 PM
Farmer Farmer is offline
Junior Member
Farmer is on a distinguished road
Default Maytag washer leaking oil
Model Number: MAV6257AWW   Brand: Maytag   Age: 5 - 10 years
Hello everyone, I have a maytag washer that is leaking oil out the bottom transmission seal. The plastic dust cover on the tail end of the shaft is covered in oil. It seems like a simple job if the seal is replaced from the bottom, ( IS IT ? ) Also, how do you check the oil level ? If it is low how do you add oil and what type of oil ? thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag agitating in one directions quicky and leaking water deborah Washer Repair 0 01-05-2008 10:16 AM
leaking maytag washer rboyd Washer Repair 5 11-11-2007 03:12 PM
leaking washer rocco Washer Repair 2 10-13-2007 12:57 PM
leaking washer jeanne Washer Repair 0 08-14-2007 06:09 PM
Maytag Washer Bottom of tub leaking at seal David S Washer Repair 4 08-11-2007 12:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
