Discuss
washer problem with spin problem
 in
Washer Repair
Ok this is my problem as best as i can explain it this washer will spin but after a while
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer problem with spin problem
  #1 (permalink)
Old 06-21-2012, 09:08 PM
Senior Member
allen9258 is on a distinguished road
Question washer problem with spin problem
Model Number: S1070A3WW   Brand: GE   Age: 1 - 5 years
Ok this is my problem as best as i can explain it this washer will spin but after a while the motor seems to over heat and stop it will start up fast then it will slow down and stop before the spin cycle is complete after it stop then it will not start up until it has had time to cool off even then it will not just start to spin some times unless you spin the tub by hand then start the spin cycle any ideas as to just what the problem or problems could be?
Ads By Google
Related Models
General Electric S1070A4WW Washer
General Electric S1070A5WW Washer
Admiral S1070EH-KZ Range - F/s Std Gas
Admiral S1070EH-Z Range - F/s Std Gas
Admiral S1070EJ-KZ Range - F/s Std Gas
Admiral S1070EJ-Z Range - F/s Std Gas
Hoover S1071--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1071800 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1073--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1075--- Port - Slim Style,suitcase,power,compact
Hoover S1075033
Hoover S1075060 Port - Slim Style,suitcase,power,compact
Hoover S1077--- Port - Slim Style,suitcase,power,compact
Hoover S1077060 Port - Slim Style,suitcase,power,compact
Admiral S1078EH-KZ Range - F/s Std Gas
Admiral S1078H-KLVW Range - F/s Cont Clean Gas
Admiral S1078W-KLVW Range - F/s Cont Clean Gas
Hoover S1079--- Port - Slim Style,suitcase,power,compact
Hoover S1079060 Port - Slim Style,suitcase,power,compact
Hoover S1083--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1083100 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Admiral S1088H-CKZW Range - S/c S/i Gas
Admiral S1088J-TKZW Range - S/c S/i Gas
Hoover S1093
Hoover S1095
Jenn-Air S110 Range - S/i Std Ddraft Ele
Hoover S1101---
Hoover S1103--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1105--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1112--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1112050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1114--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1117900 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1117981 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1120--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1120050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1127--- Port - Slim Style,suitcase,power,compact
Hoover S1133--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1135--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1137--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1137980 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1141--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1147--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1147050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1147900 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Admiral S1151L-30 Surface Unit - Ele
Admiral S1151L-36G Surface Unit - Ele
Hoover S1156--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Admiral S1171L-30 Surface Unit - Gas
Admiral S1171L-30K Surface Unit - Gas
Admiral S1171L-36GK Surface Unit - Gas
Admiral S1172L-30K Surface Unit - Gas
Jenn-Air S120 Range - S/c S/i Ddraft Ele
Jenn-Air S120-C Range - S/c S/i Ddraft Ele
Jenn-Air S121 Range - S/c S/i Ddraft Ele
Hoover S1211--- Port - Slim Style,suitcase,power,compact
Hoover S1215--- Port - Slim Style,suitcase,power,compact
Hoover S1221--- Port - Slim Style,suitcase,power,compact
Hoover S1223--- Port - Slim Style,suitcase,power,compact
Jenn-Air S125 Range - S/c S/i Ddraft Ele
Jenn-Air S125-C Range - S/c S/i Ddraft Ele
Hoover S1311--- Port - Slim Style,suitcase,power,compact
Hoover S1311020 Port - Slim Style,suitcase,power,compact
Hoover S1315--- Port - Slim Style,suitcase,power,compact
Hoover S1319--- Port - Slim Style,suitcase,power,compact
Hoover S1323--- Port - Slim Style,suitcase,power,compact
Hoover S1329--- Port - Slim Style,suitcase,power,compact
Hoover S1331--- Port - Slim Style,suitcase,power,compact
Hoover S1335--- Port - Slim Style,suitcase,power,compact
Hoover S1337--- Port - Slim Style,suitcase,power,compact
Hoover S1339--- Port - Slim Style,suitcase,power,compact
Hoover S1347--- Port - Slim Style,suitcase,power,compact
Hoover S1349--- Port - Slim Style,suitcase,power,compact
Hoover S1353--- Port - Slim Style,suitcase,power,compact
Jenn-Air S136 Range - S/c S/i Ddraft Ele
Jenn-Air S136-C Range - S/c S/i Ddraft Ele
Hoover S1361---
Jenn-Air S136B Range - S/c S/i Ddraft Ele
Jenn-Air S136B-C Range - S/c S/i Ddraft Ele
Jenn-Air S136W Range - S/c S/i Ddraft Ele
Jenn-Air S136W-C Range - S/c S/i Ddraft Ele
Hoover S1410--- Port - Slim Style,suitcase,power,compact
Hoover S1420--- Port - Slim Style,suitcase,power,compact
Hoover S1420050 Port - Slim Style,suitcase,power,compact
Amana S148CA01  Ref - SXS/I&W
Amana S148CA03  Ref - SXS/I&W
Amana S148DA01  Ref - Sxs
Amana S148DA03  Ref - Sxs
Jenn-Air S156 Range - S/c S/i Ddraft Ele
Jenn-Air S156-C Range - S/c S/i Ddraft Ele
Jenn-Air S156B Range - S/c S/i Ddraft Ele
Jenn-Air S156B-C Range - S/c S/i Ddraft Ele
Jenn-Air S156W Range - S/c S/i Ddraft Ele
Jenn-Air S156W-C Range - S/c S/i Ddraft Ele
Amana S16 Freezer - Vertical
Jenn-Air S160 Range - S/c S/i Ddraft Ele
Jenn-Air S160-C Range - S/c S/i Ddraft Ele
Jenn-Air S161 Range - S/c S/i Ddraft Ele
Jenn-Air S166 Range - S/c S/i Ddraft Ele
Jenn-Air S166-C Range - S/c S/i Ddraft Ele
Jenn-Air S166B Range - S/c S/i Ddraft Ele
Jenn-Air S166B-C Range - S/c S/i Ddraft Ele
Jenn-Air S166W Range - S/c S/i Ddraft Ele
Jenn-Air S166W-C Range - S/c S/i Ddraft Ele
Amana S16L Freezer - Vertical
Jenn-Air S176 Range - S/c S/i Ddraft Ele
Jenn-Air S176B Range - S/c S/i Ddraft Ele
Jenn-Air S176W Range - S/c S/i Ddraft Ele
Amana S19E Ref - SXS/I&W
Frigidaire S2-06B1E Kel(v0) / Room Air Conditioner
Amana S20 Freezer - Vertical
General Electric S2000D0WW Washer
General Electric S2000D2WW Washer
General Electric S2000D5WW Washer
Hoover S2001---
Hoover S2003--- Stick - Handy,broom,light Wt,compact
Hoover S2005--- Stick - Handy,broom,light Wt,compact
Hoover S2007--- Stick - Handy,broom,light Wt,compact
Hoover S2009--- Stick - Handy,broom,light Wt,compact
Hoover S2011--- Stick - Handy,broom,light Wt,compact
  #2 (permalink)
Old 06-22-2012, 01:28 AM
Junior Member
CharlesThompson is on a distinguished road
Default washer problem with spin problem
I think there must be an issue with a motor. I think the coppor wires get damaged and hence it is getting heated and stop due to heat. You need to check the motor first.Quality kitchen cabinets
  #3 (permalink)
Old 06-22-2012, 07:24 AM
Senior Member
Default
how would you recommend that i check the motor and test it for what meaning just replace it or run a series of test to determine if its bad if it needs testing i need the procedure to test it or how to go about it
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer spin problem carlito13 Washer Repair 1 08-14-2011 02:26 AM
Washer spin problem rice80flash Washer Repair 0 09-11-2010 06:58 PM
washer spin problem hitmehhh Washer Repair 1 04-15-2010 04:20 PM
Washer problem in LARGE load setting- timer problem? jagtianis Washer Repair 9 08-04-2008 02:49 AM
washer spin problem misterfixall Washer Repair 0 07-01-2008 09:27 AM
