Discuss
Washer won't drain or spin
 in
Washer Repair
Picked up this old Admiral washer. It washes and agitates fine, but only drains and spins sporadically. The timer runs
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't drain or spin
  #1 (permalink)
Old 09-13-2009, 09:24 PM
Junior Member
rjhenn is on a distinguished road
Unhappy Washer won't drain or spin
Model Number: lnc6747a71   Brand: Admiral   Age: 5 - 10 years
Picked up this old Admiral washer. It washes and agitates fine, but only drains and spins sporadically. The timer runs through, and stops if you lift the lid. Sometimes, moving the dial to a different spin cycle will get it to drain and spin, but not often. Usually when you move it to another rinse cycle the washer will agitate, but sometimes not.
It seemed briefly as if unplugging the machine for a while and trying again helped it drain and spin, but I've haven't been able to repeat that. I pulled the timer, removed the cover, visually inspected it and blew air through it to dislodge anything that might be stuck in there. No change. Timer appears visually OK.
I'm on my third load of laundry with this thing, and can't get the third load to drain and spin. Had to try several times with each of the first two loads.
Ads By Google
Related Models
Admiral LNC6760A71 WASHER-TOP LOADING
Admiral LNC6760B71 WASHER-TOP LOADING
Admiral LNC6762A01 WASHER-TOP LOADING
Admiral LNC6762A71 WASHER-TOP LOADING
Admiral LNC6762A77 WASHER-TOP LOADING
Admiral LNC6762B01 WASHER-TOP LOADING
Admiral LNC6762B71 WASHER-TOP LOADING
Admiral LNC6764A71 WASHER-TOP LOADING
Admiral LNC6766A00 WASHER-TOP LOADING
Admiral LNC6766A01 WASHER-TOP LOADING
Admiral LNC6766A71 WASHER-TOP LOADING
Admiral LNC6766A77 WASHER-TOP LOADING
Admiral LNC6766B71 WASHER-TOP LOADING
Admiral LNC7760A71 DRYER- ELE
Admiral LNC7764A71 DRYER- ELE
Admiral LNC7764A77 DRYER- ELE
Admiral LNC7766A00 DRYER- ELE
Admiral LNC7766A71 DRYER- ELE
Admiral LNC7766B71 DRYER- ELE
Admiral LNC8760A01 DRYER- GAS
Admiral LNC8760A71 DRYER- GAS
Admiral LNC8760A77 DRYER- GAS
Admiral LNC8764A71 DRYER- GAS
Admiral LNC8766A00 DRYER- GAS
Admiral LNC8766A71 DRYER- GAS
Admiral LNC8766B71 DRYER- GAS
 LP-C303R20 Air Conditioner
 LP070CED Air Conditioner
 LP070CED-Y8 Air Conditioner
 LP070CED1 Air Conditioner
 LP070HED Air Conditioner
 LP070HED-Y8 Air Conditioner
 LP070HED1 Air Conditioner
 LP090CED Air Conditioner
 LP090CED-Y8 Air Conditioner
 LP090CED1 Air Conditioner
 LP090HED Air Conditioner
 LP090HED-Y8 Air Conditioner
 LP090HED1 Air Conditioner
 LP090HEM Air Conditioner
 LP091CEM-Y8 Air Conditioner
 LP091HEM Air Conditioner
 LP1200DXR Air Conditioner
 LP120CED Air Conditioner
 LP120CED1 Air Conditioner
 LP120CEM Air Conditioner
 LP120CM3 Air Conditioner
 LP120HED Air Conditioner
 LP120HED-Y8 Air Conditioner
 LP120HED1 Air Conditioner
 LP120HEM Air Conditioner
 LP121CEM-Y8 Air Conditioner
 LP121HEM Air Conditioner
 LP121HEM-Y8 Air Conditioner
Amana LP13300.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP13300.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP13600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP13600.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP13610.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP13610.B MWAVE - FAMILY SIZE (60 HZ)
 LP150CED Air Conditioner
 LP150CED-Y8 Air Conditioner
 LP150CED1 Air Conditioner
 LP150HED Air Conditioner
 LP150HED-Y8 Air Conditioner
 LP150HED1 Air Conditioner
 LP155HED1 Air Conditioner
Amana LP16400.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP16400.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP16600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP16600.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP16610.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP16610.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP24400.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP24400.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP24600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP24600.B MWAVE - FAMILY SIZE (60 HZ)
 LP6000ER Air Conditioner
Amana LP83400.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP83400.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP83430.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP83430.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP83600.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP83600.B MWAVE - FAMILY SIZE (60 HZ)
Amana LP83620.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP83630.A MWAVE - FAMILY SIZE (60 HZ)
Amana LP83630.B MWAVE - FAMILY SIZE (60 HZ)
Frigidaire LPGF3091KSA GAS RANGE
Frigidaire LPGF3091KSB GAS RANGE
Frigidaire LPGF3091KSD GAS RANGE
Frigidaire LPGF3091KSE GAS RANGE
Frigidaire LPGF3091KSF GAS RANGE
Frigidaire LPGF3091KSG GAS RANGE
Frigidaire LPGF3091KSH GAS RANGE
Frigidaire LPGF3091KSJ GAS RANGE
Frigidaire LPHS2687KF0 REFRIGERATOR
Frigidaire LPHS2687KF1 REFRIGERATOR
Frigidaire LPHS2687KF2 REFRIGERATOR
Frigidaire LPHS2687KF4 REFRIGERATOR
Admiral LPK5404ARW KITCHEN COMPACT
Admiral LPR1115ADW RANGE- F/S STD GAS
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Frigidaire LPUS2686LF0 REFRIGERATOR
Frigidaire LPUS2686LF1 REFRIGERATOR
Frigidaire LRA050XT70 ROOM AIR CONDITIONER
Frigidaire LRA050XT71 ROOM AIR CONDITIONER
Frigidaire LRA050XT710 ROOM AIR CONDITIONER
Frigidaire LRA050XT711 ROOM AIR CONDITIONER
Frigidaire LRA050XT712 ROOM AIR CONDITIONER
Frigidaire LRA050XT713 ROOM AIR CONDITIONER
Frigidaire LRA050XT714 ROOM AIR CONDITIONER
Frigidaire LRA050XT715 ROOM AIR CONDITIONER
Frigidaire LRA050XT716 ROOM AIR CONDITIONER
Frigidaire LRA050XT717 ROOM AIR CONDITIONER
Frigidaire LRA050XT718 ROOM AIR CONDITIONER
  #2 (permalink)
Old 09-15-2009, 04:35 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I cannot get your model number to come up, but I think I know the machine you have.
I suggest you take off the pump and examine it to see if it is clogged, broken or if there is an obstruction in the drain system.
Here is a service manual which I think is for your model even though it is not listed as such.
http://www.servicematters.com/maytag...s/16026502.pdf
If the pump/drain system is ok, and the machine sometimes works the problem may be in your timer or the transmission.
__________________
  #3 (permalink)
Old 09-15-2009, 10:29 PM
Junior Member
Default
Thanks for the advice. The machine seems pretty old, but in good shape (except for this problem).
Yesterday I finally got it to drain and spin (no idea what, if anything, I did) the third load. Then it worked perfectly when I ran the third load through the rinse cycle again, and for another load. Then it gave me a bit of a problem, but finally drained. Now it's back to not draining. When it does drain, it seems to do it without any problems.
  #4 (permalink)
Old 09-16-2009, 05:53 AM
Senior Expert
APP Volunteer
Default
I am going to suggest that you replace the pump and belt, not that I know there is anything wrong with them, but that seems likes the Mr. Spock solution (logical) and I don't have anything else to suggest.
__________________
  #5 (permalink)
Old 09-20-2009, 05:04 PM
Junior Member
Default
Well, I pulled the pump today. Spins fine. I just cleaned a layer of lint off it and put it back. The belt is a bit worn, but I tend to think the problem is in the motor. There's only one belt, running from the motor to the pump to the transmission, so the pump is always powered. But when it's supposed to be draining, I don't hear anything running, even the motor spinning. I read somewhere that the motor runs in reverse for drain and spin, and sometimes it won't start in one or the other direction. Does that sound like that could be what's going on here?
  #6 (permalink)
Old 09-20-2009, 05:23 PM
Senior Expert
APP Volunteer
Default
Well, just educated guessing here but if the motor works sporadically the problem may be in the timer not sending current to the motor some times.
There could also be a problem with the wiring going to the motor, so check that out also
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Washer will not drain or spin myzippo27 Washer Repair 6 04-12-2012 11:05 PM
washer won't drain and spin caullfieldj Washer Repair 1 03-30-2009 04:39 PM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
washer will not spin or drain Martha Shelby Washer Repair 1 10-24-2007 03:59 AM
Washer won't drain or spin carrol Washer Repair 2 08-20-2007 06:37 AM
