| » Washer will not drain or spin |
Model Number: LSN1000KQ0 Brand: Whirlpool Age: 5 - 10 years
The washer performs normally until it reaches the point to drain the tub & spin. It will completely stop then, leaving the tub full of water (and wet clothes).
Advancing the dial does nothing to help, however, at some of the other dial positions, the timer can be heard "humming/buzzing". Based on the prices of new machines, I would like to repair the old one. Also, since new timers are also expensive, I would like to make sure that I check other possible parts. So far, all we have done is to manually check every other position of the dial (no help except that the humming noise occurs at some points), and made sure that the lid switch was being contacted by the tab on the lid. Thanks for any suggestions. Ads By Google Related Models |
Hi.
Unplug the washer. Open the control panel, disconnect the lid switch plug and using the multimeter check the continuity between outer contacts (lid closed). No continuity - replace the lid switch Part number: 3949247 Use the video clip for the instructions. Here are the breakdown diagrams and Replacement parts for Whirlpool LSN1000KQ0 WASHER - DIRECT DRIVE | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Execellent help. Thanks. -Rick W. |
Hi, Rick.
Don't use the washer with the lid switch bypassed. It's dangerous specially if there are kids in the house. Replace the lid switch. Simon.
__________________
| Display Modes | |
| washer does not spin, fills up and drain the water nornal but do not spin | leaderman | Washer Repair | 0 | 10-04-2010 02:28 PM |
| My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
| Washer won't drain or spin | jnheinz57 | Washer Repair | 4 | 05-23-2008 01:23 AM |
| Washer will not drain or spin | fenderi | Washer Repair | 3 | 01-19-2008 09:17 AM |
