Washer will not turn on. Turned the machine on and left the house. When we got back the machine had partially filled with water and turned itself off. Now it won't turn on at all. Tried a different receptacle and still doesn't work. What do I replace? The power cord or the control panel?
Groups: APP Team
Hi. Open the control panel, locate and check the fuse. If it's blown - replace the lid switch assembly Part number: 22001682
