| » Hot water is very slow when filling washer |
Model Number: LAT5705AAE Brand: Maytag Age: More than 10 years
When I have the temperature dial set to "Hot/Cold" or "Warm/Warm" the washer is VERY slow to fill. (More so if set to "Hot/Cold".) Is it possible I could just have sediment built up somewhere inside the washer, or is there some other fix? I have cleaned the sediment screen on the hose where it attaches to the water valve on the wall. Thanks in advance for any help you can give.
Hi.
Remove the hot water inlet hose from the washer, put inside the tub and check if the water pressure from the hose is OK. If it's fine then clean the screen inside the water valve. If that wouldn't help - replace the water inlet valve. For the part number please post the correct model number. Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
This is the water inlet valve if you need one
Part number: 22001274 Here are the breakdown diagrams and Replacement parts for Maytag LAT8705AAE WASHER-TOP LOADING | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
| Display Modes | |
| Extremely slow filling | CBValerius | Washer Repair | 4 | 09-19-2011 07:36 PM |
| Washer keeps filling up with water. | Gardner | Washer Repair | 0 | 06-30-2010 05:49 PM |
| Washer filling with water... when not on | kwkenuf | Washer Repair | 3 | 03-22-2010 08:50 PM |
| Slow Leak when Filling | mistysj | Washer Repair | 1 | 11-17-2009 11:47 AM |
| Slow fill and loud noise while filling | kloyden | Washer Repair | 0 | 07-24-2008 06:47 AM |
